This morning static check engine sign came on.... i took help of this forum to check the code.... it came out to be P0456.
I checked gas cap it looked fine but still i ordered new one.
few minutes ago again i went to see if i missed any problem on gas cap or not and i noticed that small metal lid inside the neck of fuel tank is missing.... i don't even know what is it called. That metal lid closes on its own when we take out fuel pump nozzle and goes in when we push nozzle inside.
its missing:confused:
and if it fell inside gas tank should i take it to mechanic to flush it out?
Can that be an issue for code P0456? how can i find the replacement?
Its 2006 Charger R/T
I don't think it provides much of a seal. The loose gas cap can take a couple of days to go away after you correct the issue.
thanks for the reply... but is that metal lid thing of any issue if missing?? what is called and is there any replacement number or any way to fix it?
i ordered new gas cap on ebay.... will take atleast week or so to arrive...
Suscribed - had this happen to me. Didn't have a code, just happen to notice that the little lid in the fuel tank neck was suddenly missing when I pulled out the fuel pump nozzle after recently filling up. Nothing wrong with my gas cap, and I'm not getting any codes since this happened 3 days ago. I am also wondering if this is a big deal. I am thinking it is an emissions-related thing...
The metal flapper is spring-loaded in the filler neck. Did you check to see if it got stuck open - maybe stick your finger in the filler opening and see if the flapper is hung on something. If it did happen to fall into the fuel tank, I don't think it will harm anything. The pumps have strainers on their inlets to keeps stuff from getting into the pumps.
