1 - 18 of 18 Posts
Ok, so about a year ago I take my Charger to the dealership because I sometimes feel a little vibration under the gas peddle. I thought maybe it was my suspension but it wasn't. I've been seeing a lot of threads lately about tie-rods needing replaced.
What do you guys think it is? It doesn't bother me that much but I have the lifetime warranty and the dealership said they couldn't find anything wrong.
As you can see I've had the problem for a year so it isn't causing me too much grief but if it is the tie-rod I should get it fixed.
Curious what you guys think!
Thanks :bigthumb:
Almost forgot:
Hi Dan :wave:
Hi Todd :wave:
Hi Patrick :wave:
Hi Robin :wave:
Hi Trev :wave:
Hi Turtle :wave:
Hi Julio :wave:
Hi Everyone :wave: :wave: :wave:
Hi Robin :wave:
Hi Todd :wave:
He looks like he could fix it :D
Check your tires. If you have uneven wear it could be the rods. Also I had a shimmy and uneven wear because a pot hole took a chunk out of one of my tires.
I'll check that out. I definitely have the warped rotors. I'll check the tires tonight. Thanks!
Hi LD :wave:
Is it usually at certain speeds that the gas peddle vibrates??
Hi Dan :wave:
Patrick :slap: :biggrinjester:
I feel that vibration under the throttle at various speeds...sometimes on the highway somtimes in town. It's only when the car is moving :driving:
Unfortunately, it happens around 60 and 25-35. It pretty much happens all the time. If I'm coasting I don't feel it so much.
Wheels spin differently at different speeds. If it is a wheel related issue that could be the cause of the intermittent shimmy. :banana:
Discussion Starter · #18 ·
:bigthumb: I know I need new rotors for sure.
Don't worry about it...I'm getting you an SRT.
Thanks! :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb: :bigthumb:
1 - 18 of 18 Posts
