1 - 14 of 14 Posts
alright ive had no esp installed for about 2 weeks now and never really got to test it out...well its raining today here and i got a day off from work so upon leaving the lot at work i push the button 5 seconds relay clicks lights come on i turn out onto the road let em rip...now its going good little tire spin BUT i still have brake assist stopping my wheels from spinning and mr squiggles still flashes when BAS kicks in, and i cant get the ass end to whip out IN THE RAIN...WTF im pretty sure i installed it right...anyone else have this prob? im thoroughly annoyed :(
You should have BAS/ESP and the Mr. Squiggly all lit up when you have the NoEsp turned on.
Push once, Mr.Squiggles, push again and hold for >5 sec, the BAS/ESP should lit up along with Mr. Squiggles.
i dont think you read my post carefully but thanks for the input...
BAS shouldnt be kicking in is the thing. Is the light on in your dash? Or just mr squigs?
i get both lights relays clicks i hear the chime lights come on still have bas...
hm. seems odd. tried a slick parking lot.. cranking your wheel all the way over and just stomping the throttle? if u cant swing your tail wide open there, then something is fishy.
yep def tried it wont break em loose, my build date is 05/05 and early build one of the first ones to role off the line so i hope this has nothing to do with it, im still waiting for a response from mr Noesp...
I have the exact same problem - What's strange is if I push esp button once (Mr. Squiggles) I can do donuts... If I hold it down, hear the click, BAS + Mr. Squigs are lit up, It's worse than before, the second the wheels start to spin, the motor boggs (as if a governor was engaged), and the brakes LOCK!
I know I have installed it correctly... Mine is an 07 not sure what the build date is... where do I find that, door?
Thanks, Loren
Thanks, Loren
sent u a pm
same here
I installed the no esp today, and I hear the click, chime and ESP/BAS illuminates after 5s (just like it's described in the instructions) and I'm still not able to even slightly chirp the tires. My car was build on July 2005. I have checked the wires mutiple times and I'm sure that copnnectivity is perfect.
maybe wiring is barely diff on the 05s. idk. thats a good reason for me not to use it ;/ im a very early built one
nahh it works fine now, turns out i wasnt beatin it hard enough to get real loose, plus i put some taller and wider and meatier tires on her...but i took her out one night after it had rained to an empty parking lot and did some nice burnouts and donuts, and it worked just fine no interference and a lot of smoke, i tried, with it on, and partially on, and i couldnt do any donuts:( so the chip works you just gotta make it work...:grin:
1 - 14 of 14 Posts
