So recently changed my thermostat after getting a cold and the heat not working. When I changed and bled the coolant the heat worked again for one day. Next morning I came out it was cold again and the coolant temp was fluctuating erratically. It did end up getting warm but then got cold once again. What could it be? Water pump is good, thermostats good, coolant levels good. There doesn’t seem to be any visible leaks. What should I check our do now? Bleed it again? I can’t afford a mechanic prices right now but definitely need to commute, ive been doing the best I can with no heat but the weather is starting to get in the negatives now so I can’t stand it any longer.
