Just had my pads and rotors replaced on my 2010 charger pursuit. It seems under a load and wobbles terribly at times and other times it don’t. Doesn’t matter the speed. They’re all factory correct parts and sizes. It rode smooth and perfect before. It doesn’t pull left or right and also sounds like I have mud grip tires at times. It never did this before. It was perfect,just needed brakes so I replaced pads and rotors. I work for family and use my car so the company mechanic does all maintenance. He’s not the type that does bad work or cuts corners. He used the new pad brackets that came with the pads and everything fit tight and nice. Nothing out of the ordinary during installation. Sometimes it drives smooth then it starts shaking even without the brakes depressed. Sometimes when you hit the brakes it wobbles and sometimes it doesn’t! It’s almost like a bumping from the front. All tires still have the balancing weights nothing different other than the brake job.
