We have been putting this one togethor for a while it seems. It took us a while to source just the right T-stat. Basically, there are a lot of cheap T-stats out there that "kind of fit", or don't have jiggle pins, which are very important for proper operation in a Hemi.
We finally settled on the Motorad 170 and 180 degree t-stats. They have good build quality, and come with jiggle pins. You do have to reuse your stock gasket, but that is no biggie. If you want a new gasket, or something a little beefier, we offer the premium JET 180 T-stat for an extra $9.95.
This new package only costs 375.35, and is available at the link below!-
http://marylandspeed.com/diablospor...-hemi-charger-magnum-300c-dcxsp05-p-1822.html
Everyone knows about the Predator..so we will talk T-Stats some...
What is the difference between T-stats?
- Motorad 180 Degree- Great for all cars and climates to reduce operating temperature with no real negatives. Includes jiggle pin, and you must reuse you stock gasket.
- Motorad 170 Degree- Car will run even cooler, but also increases the risk of CEL lights, and poor heater performance in cold climates. Includes jiggle pin, and you must reuse you stock gasket.
- Jet Premium 180 Degree T-Stat- Sturdier construction than Motorad T-stats. Great for all cars and climates to reduce operating temperature with no real negatives. Includes jiggle pin, and NEW gasket.
If you are not sure which temperature t-stat to use, you should pick a 180 degree one to be on the safe side. All of our T-stats include a jiggle pin. Even if you do not buy from us, be aware there are several cheap T-stats out there that do not have jiggle pins. Jiggle pins are important to your new T-stat working right in your HEMI. In terms of build quality, the Motorad is the same quality as your would get at NAPA or Advance Auto and will work fine. The Jet T-stat includes a new gasket, has more material to it, and is overall sturdier (see additional pictures). Odds are you would be fine with either brand and never have an issue.
Here are some pictures of the Jet T-sat vs the Motorad ones.
