1 - 8 of 8 Posts
I own a 2007 superbee. Before I put my car away for this past winter, I got a new transmission. It wasn't slipping but just running rough. Didn't really drive it all that much after. After starting it yesterday for the first time this year, I stepped on the gas to pass someone and all it did was revv and didn't go anywhere. I had to pull over but the car simply wouldn't go in gear. It felt like it was in neutral. after restarting the car, it worked fine, but also slipped and revved but kept driving.
I took it to the tranny place today, and the guy is saying nothing is wrong with the tranny but some sort of electrical problem. My question to you guys is, Will I need to reinstal my predator dynod tune? The guy told me the performance tune shouldnt be affected at all. The tranny has nothing to do with the tune. I also through a code because of it. Has anyone else ever had a problem like this? The tranny never slipped before the new one was put in.
The transmission you got was a newly rebuilt/re-manufactured trans? First thing I would check is the fluid level to ensure it's not low.
yes, exactly. That was the first thing he checked, was the level of fluid. Said it was full. He took it for a ride, with me in it, he stepped on the gas but didn't slip. It never happens when "they" take it for a ride though. lol He said it may never happen again. but if it does to bring it back...
I thought he said something about it over revved. I don't think it was an incorrect gear ratio though. Driving nice and normal, the car was fine, when I push the gas down fast, to pass someone, it just revved. He said it went into limp mode.
· Premium Member
If it went into limp mode, it likely stored a code as to the cause. Have you had the system read for any codes? TCM codes won't always show up with the key dance and need to be read directly.
1 - 8 of 8 Posts
