1 - 12 of 12 Posts
305/40/22 will they fit on my HEMI..
:smoke:
I got some 22" rims in the back yard from my previous ride.
It was a 99 GMC Yukon. Question is I was wondering if they fit on my 06 Charger R/T. They have Nitto 404 Extreme tires 305/40/22.:grin:
and what info did you need? whats the question?
:smoke: Bump....
wont fit...we have a metric bolt pattern...gm uses a standard pattern plus the tires will be way too big...
wont fit! completely different wheel! different lug pattern,different offset, and the tires are probably too big for the charger also
Thanks for the info.
What tire size would perfer on 22" rims?
if your 99 yukon is a 4x4 then no they wont fit for sure since they are 6 lug and your charger would be a 5.
Recommeded tires size for the SRT8 with 22's
285/30R22 28.7" tall
or 265/30R22 in an XL (extra load) rating only. 28.3" tall
Actually ...... the most popular size you'll see on a Charger with 22's is 265/35R22 (only .3" taller overall than OEM 225/60R18 or 245/45R20 and same height as the OEM 255/45R20 on the back of some SRT8's)
265/30R22 is .3-.4" shorter than OEM 225/60R18 or 245/45R20
285/30R22 I would think would be too wide for the front of these cars
Thanks for the info.. :smoke:
1 - 12 of 12 Posts
