1 - 4 of 4 Posts
Can you wet sand clear coat??? I am painting my tails, and a little debris blew into the clear as I was spraying. Can I wet sand it out? Need some paint pro help please. Thanks folks.
Absolutely. Wet sanding the clear coat is what you want to do. Just be careful not to "burn" through the paint.
Edit: Even if there is only clear coat, no paint underneath, you most definitely can, and should, wet sand it.
Thank ya! I decided to try it, and it took all the little crud out. Then applied another coat of clean after a solid rinse of the parts. My little experiment turned out better than I had hoped, though not as good as I would have liked. Think I have a fix though in the works <EG>
1 - 4 of 4 Posts
