Includes all bulletins released through: August 31, 2007
Includes all LX Models when applicable: 300 series, 300C, 300N, 300M, Magnum, Charger and all RT and SRT8 Models
Upcoming bulletins:
(None scheduled)
1. TSB's (Technical Service Bulletins)
Part A: Multiple Model Years 2005 - 2008
TSB Date .. Model Yr … TSB # …............................ Description...................... (Applicable models)
08/31/07 … 0508 .. #22-003-07 …. Wheel Lug Nuts .. (3MR)
08/08/07 … 0508 .. #23-035-07 …. Exterior Lamp - Lens Fogging .. (3MR)
06/06/07 … 0607 .. #08-015-07 …. Flash: Sunroof Module, Excessive IOD, Pop In Radio, Dome Lamp Flickers .. (3MR)
05/16/07 … 0507 .. #08-001-07b .. Passenger Air Bag Deactivation (supersedes 08-001-07b) .. (3MR)
04/27/07... 0607 .. #18-026-07a .. Flash: ND 4.7L - Downstream Oxygen Sensor - Slow Response &/or Fuel Trim DTC's .. (3MR)
04/17/07 … 0607 .. #18-027-07 …. Flash: MIL Illum. EGR Position Sensor DTC P0404, P0405, or P0406 .. (3MR)
04/13/07 … 0607 .. #05-001-07 …. Police Brake Front Pad Lining Life and Noise .. (MR)
03/30/07 … 0507 .. #26-003-07 …. Fluid Flushing Requirements .. (3MR)
02/09/07 … 0507 .. #21-003-07 …. Automatic Transmission Diagnostic Tear Down Procedure .. (3MR)
02/07/07 … 0607 .. #11-001-07 …. Turbocharger, Chg. Cooler & EGR Sy. Diag. on OM642 Eng. (export) .. (3MR)
02/07/07 … 0507 .. #08-001-07a .. Passenger Air Bag Deactivation (supersedes 08-001-07) .. (3MR)
02/02/07 … 0607 .. #23-005-07 …. "A" Pillar Water Leak .. (3MR)
01/03/07 … 0506 .. #08-001-07 …. Passenger Air Bag Deactivation (supersedes 08-032-05) .. (3MR)
12/20/06 … 0506 .. #21-020-06 …. Delayed Or Rough 1-2 shift at WOT After Kickdown (6.1L only) .. (SRT)
12/19/06 … 0607 .. #18-012-06a .. MAP Sensor, DTC's P0652/P0340/C121C/P2127 (supersedes 18-012-06) .. (3MR)
12/09/06 … 0506 .. #09-011-06 …. Engine Whine Sound at Idle (6.1L only) .. (SRT)
12/05/06 … 0607 .. #08-049-06 …. Instrument Cluster Resets If Driver Exits Vehicle… .. (3MR)
11/17/06 … 0506 .. #18-035-06 …. FLASH: Malfunction Indicator Lamp (MIL) On For P0573 .. (3MR)
10/28/06 … 0506 .. #18-031-06 …. Flash: Delayed Engine Crank or MIL DTC P0573 (2.7L/3.5L) .. (3MR)
10/21/06 … 0607 .. #23-047-06 …. Cracked Windshield .. (3MR)
10/14/06 … 0507 .. #23-045-06 …. Ratcheting Sound During Sunroof Operation .. (3MR)
10/04/06 … 0607 .. #22-004-06 …. Tire Pressure Monitor - System Information (supersedes 22-002-05) .. (3MR)
10/03/06 … 0506 .. #21-012-06b .. Flash: 1-2 Upshift Shudder or Rough Shift (2.7L and 3.7L only) .. (3MR)
09/27/06 … 0607 .. #23-041-06 …. Exterior Lamp - Lens Fogging .. (3MR)
09/26/06 … 0506 .. #23-040-06 …. FLASH: Rear Of Sunroof Glass Not Flush To Roof/Sunroof Will Not Close .. (3MR)
09/16/06 … 0506 .. #09-010-06 …. Multiple Cylinder Misfire Or Rough Idle (3.7L, supersedes 09-005-05) .. (3MR)
09/09/06 … 0607 .. #26-007-06 …. Owner Manual Addendum - Maint. Sched. Diesel Eng.- Export Only .. (3MR)
09/09/06 … 0607 .. #26-008-06 …. Owner Manual Addendum - Fluids & Capacities - Export Only .. (3MR)
08/02/06 … 0507 .. #24-006-06 …. A/C Cooling Coil Odor (supersedes 24-013-05) .. (3MR)
08/02/06 … 0506 .. #05-006-06 …. Front And/Or Rear Brake Rotors Grooved/Scored .. (SRT)
07/27/06 … 0506 .. #23-031-06 …. Windshield Header Buzz Or Humming Sound .. (3MR)
06/15/06 … 0506 .. #21-012-06a .. Flash: 1-2 Upshift Shudder/Rough Shift 2.7/3.5 (supersedes 21-012-06) .. (3MR)
05/27/06 … 0507 .. #08-025-06 …. Poor Radio Reception (supersedes 08-32-04) .. (3MR)
05/24/06 … 0506 .. #08-024-06 …. Flash: Memory Seat/Memory Steering Column (supersedes 08-027-05) .. (3)
05/13/06 … 0506 .. #18-018-06 ... FLASH: MIL Illumination DTC P2112 Or P1521 (supersedes 18-035-05a) .. (3MR)
05/10/06 … 0506 .. #23-019-06 …. Adhesive Residue From The Protective Covering On Carpeting .. (3MR)
04/26/06 … 0506 .. #08-017-06 …. StarSCAN® Vehicle Scan Report Availability .. (3MR)
04/26/06 … 0506 .. #11-002-06 …. MIL lamp Illuminated and/or Exhaust Rattle (export models) .. (3)
04/19/06 … 0506 .. #21-011-06 …. Transfer Case Shudder (AWD models) .. (3M)
04/14/06 … 0506 .. #21-010-06 …. Automatic Transmission Fluid Usage ATF+4 (Type MS9602) .. (3MR)
04/01/06 … 0506 .. #08-015-06 …. FLASH: Illuminated Approach, Fog Lamps and/or Rear Wiper Operation .. (3MR)
03/16/06 … 0506 .. #08-014-06a .. Flash: UConnect Fails To Respond (supersedes 08-049-05) .. (3MR)
03/08/06 … 0506 .. #23-014-06 …. Windshield Wiper Blade/Element Maintenance .. (3MR)
02/18/06 … 0506 .. #21-003-06 …. Dipstick Seal May Leak Causing ATF Contam. Or Trans. Shudder .. (3MR)
02/16/06 … 0506 .. #19-002-06 …. Moan/Groan Sound Heard At Idle (3.5L models) .. (3MR)
01/18/06 … 0506 .. #23-002-06 …. Sunroof Rattle Sound .. (3MR)
01/12/06 … 0506 .. #23-001-06 …. Sill Cladding Replacement .. (3M)
12/02/05 … 0506 .. #08-032-05a .. Passenger Air Bag Deactivation Procedure .. (3MR)
12/02/05 … 0506 .. #09-005-05 …. Multiple Cylinder Misfire Or Rough Idle (3.5L) .. (3MR)
11/18/05 … 0506 .. #18-035-05a .. DTC P2112 Or P1521 (superseded by 18-018-06 dated 5/13/06) .. (3MR)
11/12/05 … 0506 .. #21-019-05a .. Transfer Case Shudder (supersedes 21-019-05) .. (3M)
11/04/05 … 0506 .. #23-052-05 …. Rear Fascia To Body Side/Tail Lamp Fit .. (3R)
10/26/05 … 0506 .. #19-008-05 …. Revised Power Steering System Bleeding Procedures .. (3MR)
10/08/05 … 0506 .. #21-019-05 …. (superseded by #21-01905a dated 11/12/05) .. (3M)
10/04/05 … 0506 .. #05-005-05 …. Front And/Or Rear Brakes Squeal When Braking .. (SRT)
10/04/05 … 0506 .. #21-018-05 …. Automatic Transmission Diagnostic Teardown Procedure .. (3MR)
10/01/05 … 0506 .. #08-013-05a .. UConnect Phone Inoperative (supersedes 08-013-05) .. (3MR)
09/21/05 … 0506 .. #23-043-05 …. Headliner Fit At Backlight .. (3R)
09/09/05 … 0506 .. #23-042-05 …. Liftgate Spoiler Outer Seal Delamination .. (M)
09/09/05 … 0506 .. #23-041-05 …. Deck Lid Spoiler Fit .. (SRT)
09/01/05 … 0506 .. #08-049-05 …. Flash: Uconnect Module No Response Due To Module "Lock Up" .. (3MR)
08/30/05 … 0506 .. #23-040-05 …. Gap Between Carpet & Scuff Plate (supersedes #23-021-04) .. (3MR)
08/23/05 … 0506 .. #21-014-05 …. FLASH: Click Sound From Rear of Veh. After Accel. From Stop .. (3M)
08/04/05 … 0506 .. #24-013-05 …. A/C Cooling Coil Odor .. (3M)
07/26/05 … 0506 .. #23-035-05 …. Circular/Ring Marks On Glass .. (3MR)
07/21/05 … 0506 .. #18-031-05 …. Flash: Shift Hesitation During Wide Open Throttle 6.1L .. (SRT)
07/14/05 … 0506 .. #21-011-05a .. NAG1 (W5A580) Trans Shudder Trq Cnv Clutch Engages .. (3MR)
06/30/05 … 0506 .. #08-034-05 …. MIL Illum. O2 sensor P0037, 0058, 131-133, 138, 151, 153 .. (3MR)
06/03/05 … 0506 .. #19-004-05 …. Steering Column Power Tilt Inoperable.. (3)
05/25/05 … 0506 .. #08-027-05 …. Memory Seat/Memory Steering Column[/font][/color][/font][/color].. (3)
05/04/05 … 0506 .. #08-024-05 …. Radio Communication Equipment Install Recommendations .. (3MR)
04/02/05 … 0506 .. #23-022-05 …. Low Gloss Interior Trim maintenance .. (3MR)
04/02/05 … 0506 .. #24-007-05 …. Knock Sound Heard At Idle With A/C On (A/C clutch/pulley) .. (3MR)
03/12/05 … 0506 .. #02-002-05 …. Right Lead/Revised Alignment Specifications .. (3M)+(SRT)
02/16/05 … 0506 .. #08-013-05 …. (superseded by #0801305a dated 10/01/05) .. (3MR)
02/02/05 … 0506 .. #23-006-05 …. Ash Tray Will Not Open, Will Not Stay Closed etc. .. (3M)
Part B: 2008 models ONLY:
07/11/07 … 2008 .. #08-014-07 …. EVIC Oil Change Indicator System Service .. (3MR)
Part C: 2007 models ONLY:
07/17/07 … 2007 .. #21-002-07b .. Flash: Torque Converter Shudder / Shift Quality Improvements / DTC P0732 .. (3MR)
07/17/07 … 2007 .. #21-012-07 …. FLASH: MIL Illumination With DTC P0741- Torque Converter Clutch Circuit .. (3MR)
06/26/07 … 2007 .. #08-011-07a .. Inoperative Power Window Express Up Feature .. (3MR)
06/09/07 … 2007 .. #18-038-07 …. Flash: 6.1L - SRT8 - Charging System Voltage .. (SRT)
03/08/07 … 2007 .. #08-008-07 …. Flash: Wireless Control Module (WCM) .. (3MR)
03/07/07 … 2007 .. #18-003-07a .. Flash: MIL Illumination DTC P1004 - Short Runner Valve Performance .. (3MR)
02/16/07 … 2007 .. #18-011-07 …. FLASH: DTCP0420/P0430 Catalyst Efficiency Rationality .. (3MR)
02/16/07 … 2007 .. #18-012-07 …. Flash: MIL Illumination DTC P013A/P013C O2 Sensor Slow To Respond .. (3MR)
01/31/07 … 2007 .. #21-002-07 …. Flash: Torque Converter Shudder / Shift Quality Improvements .. (3MR)
01/26/07 … 2007 .. #23-004-07 …. Transit Film Removal .. (3MR)
09/21/06 … 2007 .. #08-042-06 …. Oil Press Indicator Illum. - Harness Contacts Compressor Pulley (3.5L) .. (3MR)
Part D: 2006 models ONLY:
10/13/06 … 2006 .. #21-019-06 …. Idle RPM Flare Cold Vehicle - Trans Oil Fill revision (export models) .. (3)
09/01/06 … 2006 .. #23-037-06 …. Deck Lid Rubbing The Paint Off Of The Rear Fascia .. (R)
05/04/06 … 2006 .. #18-016-06 …. Flash: MIL Illumination - DTC P0300 - Multiple Cylinder Misfire .. (3MR)
05/02/06 … 2006 .. #08-018-06 …. No Radio Audio Or Display Following Engine Crank .. (3MR)
04/27/06 … 2006 .. #09-005-06 …. Swirl Chamber Linkage Clip May Bind, DTC P1270 (export models) .. (3MR)
04/20/06 … 2006 .. #21-012-06 …. Flash: 1-2 Upshift Shudder/Rough Shift (2.7L with 42RLE trans) .. (3MR)
03/23/06 … 2006 .. #18-011-06 …. Rough Idle, MIL Illumination, DTC P0303 (2.7L) .. (3MR)
02/08/06 … 2006 .. #08-006-06 …. Police Vehicle Upfit/Modification Information .. (MR)
01/27/06 … 2006 .. #08-004-06 …. Passenger Airbag Disabled Lamp .. (3MR)
01/26/06 … 2006 .. #23-005-06 …. Sill Cladding Rattle Sound .. (3MR)
01/21/06 … 2006 .. #14-001-06 …. Loose Fuel Cap Message or MIL for Trouble Code P0457 .. (3MR)
01/18/06 … 2006 .. #23-003-06 …. Paint Repair - Insect Etching .. (3M)
01/12/07 … 2006 .. #23-002-07 …. Front Door Glass Pops Out Of Run Channel .. (3MR)
11/19/05 … 2006 .. #24-012-05a .. Hot Air A/C at Start-up & A/C Sys No Cool After Ext. Driving .. (3MR)
12/07/05 … 2006 .. #22-002-05 …. Tire Pressure Monitor - System Information .. (3MR)
12/02/05 … 2006 .. #08-061-05 …. Flash: No Start Due To Lost WCM Comm. (international only) .. (3MR)
11/19/05 … 2006 .. #24-014-05a .. A/C System No Cool Extended Driving Hot & Humid Conditions .. (3MR)
10/21/05 … 2006 .. #08-056-05 …. Flash: Speaker Cutout At High Volume Or Bass Setting .. (R)
09/21/05 … 2006 .. #23-044-05 …. Trunk Carpet Fit .. (3)
09/29/05 … 2006 .. #08-038-05 …. Flash: Automatic Headlamps Sensitivity Improvement .. (3MR)
07/23/05 … 2006 .. #21-012-05 …. New 42RLE Variable Line Pressure Transmission info (VLP) .. (3MR)
04/27/05 … 2006 .. #08-022-05 …. Flash: EVIC Displays extra Characters .. (3M)+(SRT)
Part E: 2005 models ONLY:
10/19/05 … 2005 .. #08-055-05 …. Satellite Radio Intermittent Static .. (3M)
08/27/05 … 2005 .. #23-028-05a … Rear Of Sunroof Glass Not Flush .. (supersedes #23-028-05) (3M)
08/19/05 … 2005 .. #23-038-05 …. Sunroof Squeaks While Opening Or Closing .. (3M)
06/30/05 … 2005 .. #18-029-05 …. Co-Pilot Support and Correct Cable Usage .. (3M)
05/27/05 … 2005 .. #18-026-05 …. FLASH: Rough Idle, Idle Sag, Cruise Control Fails To Engage.. (SRT)
05/07/05 … 2005 .. #21-002-05 …. Automatic Transmission Fluid (ATF) Weepage .. (3M)
05/05/05 … 2005 .. #23-028-05 …. Rear Of Sunroof Glass Is Not Flush To Roof .. (3M)
03/23/05 … 2005 .. #08-020-05 …. Customer Would Prefer Louder Tone From Park Assist System .. (3)
03/22/05 … 2005 .. #19-002-05 …. Variable Steering Effort In Cold Temperatures .. (3M)
03/22/05 … 2005 .. #21-009-05 …. DTC's P0750, P0755, P0760, P0765, P0846, P0871 or P0841 .. (3M)
03/18/05 … 2005 .. #08-018-05 …. Compass Display Does Not Update .. (3M)
03/16/05 … 2005 .. #08-017-05 …. Headlamps Remain On After Delay Time Out .. (3M)
03/12/05 … 2005 .. #23-007-05a .. Rear Shelf Speaker Buzz/Rattle Sound .. (3)
03/10/05 … 2005 .. #23-018-05 …. Pop/Snap Sound On Right Side Of Instrument Panel .. (3M)
03/02/05 … 2005 .. #08-015-05 …. Powertrain Control Module Initialization .. (3M)
02/25/05 … 2005 .. #23-011-05 …. Rear Grab-Handle Bezel Broken At Screw Boss .. (3M)
02/25/05 … 2005 .. #23-012-05 …. Rattle Sound From Headliner, Rear Shelf Or C- Pillar .. (3)
02/22/05 … 2005 .. #18-011-05 …. Flash - Engine Roughness or Idle Fluctuation .. (3M)
02/17/05 … 2005 .. #08-014-05 …. Mopar Acces Rem Starter Inoperative Due To Hood Switch .. (3M)
02/11/05 … 2005 .. #24-004-05 …. Flash: Poor/Intermitt. A/C Performance (supersedes 24-005-04) .. (3M)
01/14/05 … 2005 .. #21-002-05 …. Automatic Transmission Fluid (ATF) Weepage .. (3M)
01/12/05 … 2005 .. #18-003-05 …. Flash: Headlights Fluctuation and/or Int. Lamps Fluctuation .. (3M)
12/08/04 … 2005 .. #18-044-04 …. Cold Start Idle Cycling Or Radiator Steaming At Idle .. (3M)
11/29/04 … 2005 .. #19-010-04 …. Power Steering Fluid Contamination .. (3M)
11/22/04 … 2005 .. #25-001-04 …. Evaporative Systems Service procedures .. (3MR)
11/18/04 … 2005 .. #23-048-04 …. A-Pillar Molding Fit/Wind Noise .. (3M)
11/12/04 … 2005 .. #18-031-04a .. Flash, PCM: DTC P0116, P0139, P0159, P0197, U110B, U1402 .. (3M)
11/04/04 … 2005 .. #09-015-04 …. Engine Oil Viscosity Grades for 5.7L MDS engines .. (3M)
10/22/04 … 2005 .. #23-044-04 …. Puncture In Carpet At Drivers Footrest .. (3M)
10/20/04 … 2005 .. #08-034-04 …. Flash: Theft Security Sys - No Horn During Alarm (export Models) .. (3)
10/15/04 … 2005 .. #08-033-04 …. Left Fr Door Speaker Cut Out At Hwy Speed (export Mag & 300 Tour.)
10/06/04 … 2005 .. #21-006-04a .. Shudder During Shifts .. (3M)
09/30/04 … 2005 .. #08-031-04a .. Cluster Language (Non-Eng.) and/or Metric Selection Not Saved .. (3M)
09/23/04 … 2005 .. #23-038-04 …. Rear Door Glass Binds .. (3M)
09/22/04 … 2005 .. #08-032-04 …. Poor Radio Reception .. (3M)
09/13/04 … 2005 .. #18-009-04a .. Generic Powertrain Control Module (PCM) Procedure .. (3M)
08/06/04 … 2005 .. #09-013-04 …. Gasoline Engine Oil Quality And Viscosity Grades .. (3M)
08/05/04 … 2005 .. #23-031-04 …. A-Pillar Interior Trim Molding Color .. (3M)
07/30/04 … 2005 .. #08-027-04 …. Safety Systems - Vehicle Modifications/Repair .. (3M)
07/27/04 … 2005 .. #08-026-04 …. Amb. Temp Display Slow to Update/Cluster Language Correction .. (3M)
07/08/04 … 2005 .. #21-009-04 …. Flash: TCM Initialize EGS-52 Procedure .. (3M)
06/29/04 … 2005 .. #23-024-04 …. Lift Strap On The Cargo Tri-Fold Load Floor Detaches .. (M)
06/21/04 … 2005 .. #18-027-04 …. Flash: Rough idle or High RPM on Start or Spark .. (3M)
06/15/04 … 2005 .. #02-004-04 …. Suspension/Towing/Lifting Damage .. (3M)
06/15/04 … 2005 .. #23-023-04 …. Windshield Header Buzz Or Humming Sound .. (3M)
06/08/04 … 2005 .. #23-021-04 …. Gap Between Carpet And Front Door Scuff Plate .. (3M)
06/01/04 … 2005 .. #23-020-04 …. Hood Secondary Catch Binding .. (3M)
05/25/04 … 2005 .. #08-021-04 …. Erroneous Radio Diagnostic Trouble Code B221E .. (3M)
05/18/04 … 2005 .. #08-019-04 …. Light Rain Sensor Module Calibration Update .. (C)
05/18/04 … 2005 .. #23-018-04 …. Left Front Door Glass Run Distortion .. (3M)
05/04/04 … 2005 .. #08-018-04 …. Wiper Linkage Contacts MAP Sensor Wiring .. (3M)
04/27/04 … 2005 .. #08-016-04 …. Premium Audio System Intermittent Output .. (3M)
04/27/04 … 2005 .. #23-012-04 …. Real Wood Trim Scratch Repair .. (3M)
04/06/04 … 2005 .. #08-013-04a .. Recal. Procedures Req'd After Batt Disconnect (ESP/Windows) .. (3M)
03/25/04 … 2005 .. #02-003-04 …. Right Lead (superceded by 02-002-05 dated 3/12/05) .. (3M)
03/23/04 … 2005 .. #08-012-04 …. Loss of DTC's Set In Mtple Modules During New Veh. Prep. .. (3M)
03/16/04 … 2005 .. #21-004-04 …. Automatic Trans Fluid Usage ATF+4 (Type 9602) .. (3M)
01/06/04 … 2005 .. #08-001-04 …. Front Passenger Airbag Safety Precautions .. (CNM)
09/26/03 … 2005 .. #22-004-03 …. Chrome Wheel Care .. (CM)
2. RECALLS
03/00/07 … 2006 … RC-F47 … Catalytic Converter & Reprog. PCM (replaces TSB 11-002-06A) … (3MR)
02/00/07 … 2007 … RC-F50 … Reprogram ABS Control Module … (3MR)
10/00/06 … 2007 … RC-F43 … Reprogram PCM – Transmission Shift Logic (42RLE) … (3MR)
08/00/06 … 0506 … RC-F33 … Directional Signal Bulb Function (export models only) … (3MR)
06/20/06 … 2006 … RC-F18 … Rear Brake Tubes (2.7L only) … (3MR)
11/22/05 … 0506 … RC-E14 … Transmission Cup Plug Bracket … (3MR)
09/04/04 … 2005 … RC-D38 … Emissions Recall - VECI Label Replacement … (CM)
07/02/04 … 2005 … RC-D21 … Safety Recall - Rear Floorpan Reinforcement Spot Welds … (3M)
07/02/04 … 2005 … RC-D28 … Safety Recall - Battery Cable Bulkhead Stud Fasteners … (3M)
07/02/04 … 2005 … RC-D30 … Safety Recall - Shoulder Belt Adjuster Turning Loop Bolts … (3M)
05/01/04 … 2005 … RC-D25 … Emissions Recall - Replace PCM and Install Correct Software … (C)
3. CUSTOMER SATISFACTION NOTICES (CSN's)
08/00/06 … 2006 … CSN-F35 … Engine Connecting Rod Bearing Debris (3.5L engines only) … (3MR)
06/00/06 … 2006 … CSN-F27 … Replace Manifold Absolute Pressure Sensor (LE export only) … (3)
05/00/06 … 2006 … CSN-F20 … Reprogram Wireless Control Module (LE export models only) … (3MR)
12/22/04 … 2005 … CSN-D36 … Instrument Cluster Gauge Accuracy - reprogram gauges … (3M)
11/01/04 … 2005 … CSN-D49 … Compact Spare May Contact Front Susp. Ball Joint Stud … (3M)
11/01/04 … 2005 … CSN-D50 … Radiator Isolator Brackets may crack … (3M)
11/01/04 … 2005 … CSN-D51 … Low Anti-Freeze Concentration Level … (3M)
07/02/04 … 2005 … CSN-D29 … Reprogram PCM - Electronic Throttle Control … (3M)
06/17/04 … 2005 … CSN-D27 … Tire and Loading Information Label … (3)
4. RAPID RESPONSE TRANSMITTALS
08/16/07 … 2007 … RR-07030 … Auto Dimming Exterior Passenger Mirror
08/02/07 … 0607 … RR-07026 … Engine Coolant Check on 3.5L and 6.1L engines … (3MR)
02/14/07 … 2007 … RR-07003 … FLASH: 3.5 L – California (Five State) Emissions, Mil Illumination … (3MR)
01/17/07 … 2007 … RR-07001 … Flash: Torque Converter Shudder Prevention/Shift Quality (2.7L only) … (3MR)
09/19/06 … 2007 … RR-06041 … FLASH – Front Control Module … (3MR)
09/01/06 … 2007 … RR-06034 … 2007 LX Oil Pressure Switch Harness … (3MR)
07/07/06 … 2006 … RR-06025b ..3.5L #2 Rod Bearing & Crankshaft Journal Inspection for Contamination … (3MR)
04/05/05 … 2006 … RR-06017 … Piston Pin Retaining Ring … (SRT)
10/21/05 … 2006 … RR-05031 … Hood Release Cable Grommet Not Seated … (3MR)
09/27/05 … 2006 … RR-05027 … Sunroof Will Not Close (Flash) … (3MR)
09/13/05 … 2006 … RR-05025 … Engine Coolant Antifreeze Protection … (3MR)
08/26/05 … 2006 … RR-05023 … Relieve Tension In Left Downstream Oxygen Sensor Wiring … (SRT)
08/09/05 … 2006 … RR-05020 … FLASH - Wireless Control Module Ignition Off Draw … (3MR)
05/05/05 … 2006 … RR-05007 … Glove box - Incorrect Kit … (3M)
11/05/04 … 2005 … RR-04026 … Engine Cooling Module Revision … (M)
10/08/04 … 2005 … RR-04023 … Transfer Case Vent Hose Mis-routed … (M)
06/30/04 … 2005 … RR-04016 … Coolant Recovery/Overflow Container Inspection … (3M)
05/28/04 … 2005 … RR-04013 … No Start or Transmission In Limp-In Mode … (3M)
Chart notes:
Model Year:
Model Year "2005" = 2005 models
Model Year "2006" = 2006 models
Model Year "2007" = 2007 models
Model Year "0506" = 2005 and 2006 models
Model Year "0607" = 2006 and 2007 models
Model Year "0507" = 2005 through 2007 models
Model Year "0508" = 2005 through 2008 models
Applicable models code:
(3) = 300 series (may apply to ALL 300 series models including SRT8)
(C) = 300C (may apply to ALL 300C series models including SRT8)
(N) = 300N (may apply to ALL 300N series models)
(M) = Magnum (may apply to ALL Magnum models including SRT8)
(R) = Charger (may apply to ALL Charger models including SRT8)
(SRT) = SRT8 models ONLY (Magnum, Charger and/or 300C)
Examples: (3M) = 300 and Magnum; (CM) = 300C and Magnum, etc.
Important:
Some bulletins may apply only to specific production dates, models and/or equipment. Not all affected vehicles will exhibit described problems, failure rates may vary widely. Not all bulletins involve repair issues, some are issued for informational purposes only.
TSB's are not Recalls. "Preventive" service repairs will normally not be performed under warranty if a vehicle is not exhibiting the particular symptom or problem.
For vehicles that are out of warranty, any TSB related work that is performed is usually charged at the normal dealer service rate.
