I have a 2007 dodgr charger r/t with the 5.7. I took off my mopar cool air intake off to make sure there was no debris in it and to clean the filter also and when I put out back on I started the car and my engine light came on.i don't know why it came all I know is that I need it off. I put it back on exactly the way it was on screw and wires all connected where they were I need help. I don't know what the problem is :(
Have you done the key-dance to see what code you're getting?
Turn key to ON
then back to ACC
then to ON
then back to ACC
then to ON
Write down code that appears on the EVIC.
Discussion Starter #4
no I will go do that now and let you know what it says
Sent from my SCH-I510 using AutoGuide.Com Free App
DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
My suggestion is to disconnect the sensor and clean both ends, then reseat. Did you happen to bend the wires at all? I ruined mine that way and had to splice in a replacement.
Discussion Starter #7
I didn't bend the wire at all and I'll try it and hope it works
