Hi guys:D
am glad of Registering in this awesome forum
am a big fan of chevy but decided finaly to try dodge cars:rocker:
my experience is simple in dodge compared to chevy
My question to you what is the BEST bolton for the dodge charger r/t 5,7L 2008
Air intake
Headers
Cat back
And I know that you will advise me by your experience:)
Ps: the money and the high sound of the car is not a problem;)
and i hope that you guys give dyno numbers if you know for the same car and the same parts on it
Thanks in advance
Hussam
The absolute first performance item you must purchase is the Predator.
Welcome to the forums, check out the two threads in my signature block.
x2 on the first performance item .... the Predator is the biggest bang for the buck, and will make all future mods better or it will be needed for the bigger mods (heads/cams/injector/engine swaps)
And yes, check out those 2 threads :)
Part deux thanks for your replay and for the threads in your signature it's realy helpful:)
about the predator for sure it's on my list:D
ohhh man i hope that hp tuner do something to dodge cars:confused:
i dont think they will. i have been looking at hp for a while
Predator for sure. It allows you to make the most of your mods......good luck.
Predator, first mod...
Kooks, Dynatech, SLP, Longtubes... Best bet is with the Kooks...
JBA has some short tube headers, another good choice, and they have mid pipes, with or without highflow cats...
Catback, loudest, the SLP, Corsa though is loud at WOT but in normal cruising no drone, I have the Borla 112, and took off the rear resos, now its a 125, its loud enough for me...
Also consider the Modern Muscle 85mm Throttle body...
180-170 Thermostat
Air intakes, AFE and K&N are good choices, mine is an ARIA in Carbon fiber to match my engine bay... There are so many choices in the this field cant really put ur finger on it...
