1 - 12 of 12 Posts
Ok I was driving today with my ESP Disable switch on and when I stepped on the gas it seemed as if it was going to dwonshift but it didnt! Instead it seems like it shifted to nuetral and the CEL light came on. Any help will be greatly appreciated thanks in advance.
Check for codes. With the car off, turn the ignition acc-on-acc-on-acc-on
Important: do NOT turn to start while doing this, just acc and on.
The odometer should change to ---- then cycle through any codes that are recorded, then indicate dONE. Post the codes here and we can try to decipher them.
Ok I did but nothing happened????
Alright it finally happend I guess I was waiting to long to switch from acc to on. Nothing came up onle ------ and then done. It chimed like 6 times and thats it.
Ok that was weird I was driving my car around taking care of some things before I took my car in and the CEL went away before I could even get it to the dealership. Weird I guess I will just have to keep an eye out in the future, and also I never was able to pull a code from it even with the CEL on.....
1 - 12 of 12 Posts
