Vengeance is good people, your car is not in Knoxville. lol
yeah i know its not there. me and ryan know each other so he gives me sh!t about wanting to drive my car after the track 2 is in. well the bee is mine after that. no vengeance has done some work for a few others that i know and they do a top notch job.Vengeance is good people, your car is not in Knoxville. lol
Oh - OK - my bad. Sounded like accusations might have been made elsewhere.:bigthumb:I think it was brought up rhetorically.
Just what would have been your stance 'had' this bolt popped out whilst metgo was accelerating down an on-ramp (using the full potential of the system - of course) and the suspension had suddenly dropped, or popped out (dependent on the dynamics). Think it would still have been fine? What about if he'd gone to a track day?His life was never in danger. A lower rear shock but was left off or not tightened properly. The lower rear shock bolt is under load even when the car in on a lift with the wheels at full droop.
Note to DCX: You are wasting money on nuts for your lower damper bolts because the bolts clearly stay in all by themselves........
In a worst case scenario the bolt falls out and the shock is trapped in the lower control arm pocket. It makes noise and does little else. That is the fact of the matter.
Note to DCX: You are wasting money on nuts for your lower damper bolts because should the worst happen and they fall it - it only makes a noise.....
I never denied that Pedders makes a great product. To this day I stand by it, my Pedders suspension is awesome, it is like nothing I've ever experienced before. But there is other matters at hand, so quite trying to change the subject. I've told both you, Paul and MCP that I think I deserve compensation for all the problems you caused me and I keep getting brushed off and you continue to act like this isn't a big deal and it is normal. I'm not the bad guy here, you are.His life was never in danger. A lower rear shock but was left off or not tightened properly. The lower rear shock bolt is under load even when the car in on a lift with the wheels at full droop. In a worst case scenario the bolt falls out and the shock is trapped in the lower control arm pocket. It makes noise and does little else. That is the fact of the matter. It is also a fact that the mistake was made. The shop apologised. MCP apologised. The car was fixed. That should have been the end of the story. It wasn't. Being Pedders when the car showed up at the LX Nationals were inspected it. Eric from Backstreet performance crawled around in the dirt on the ramps to the dyno and checked every bolt in the suspension. Eric is built like a fireplug and found a nut he could tighten a bit more. To be very clear, there was no customer issue with the suspension at this point, we were just making sure. That turns into my car is falling apart and MCP sucks. We continue to provide free dyno and A/F pulls. That turns into FREE dyno services aren't good enough because the graph isn't large enough and why don;t you reprint it foir me. By the time he left the display he wasn't happy nor were any of the Dealers, nor was I. Then we end up with a noise weeks later that may have been the front sway bar bracket, but no one is certain there wasn't really anything wrong on the last shop inspection. Keep in mind, there are numerous posts on this forum and other LX forums of 100% box stock LXs various noises. When you touch a suspension, you have to be prepared to own every noise it makes after that. Pedders and our Dealer assume that role and risk. So now the customer leaves the shop after everything has been rechecked for the I don't know how many times and appears to be happy until the post we see here.
Enough is enough. The customer NEVER asked for or discussed any form of 'compensation' for his headaches and time with Pedders until he posted in multiple forums. It was never even hinted at. He could not and should not have been expecting a phone call from Pedders for two weeks, because there was no conversation, PM, email or any other type of exchange regarding compensation. Everything the customer asked for we gave him. Everything. Are we giving him something after this flaming thread -- other than his warranty for his bits and installation at any of the Pedders Dealers nationwide that he already had -- no.
Btw, the last conversation I had with this customer he told me he loved his Pedderised LX. That was after the Pedders track-side service at the Nationals when he was in line to make one last pass down the drag strip. He knows this is accurate. He knows exactly what I think of this post. He has never called to discuss anything in the last two weeks or made any attempt at any communication with Pedders in this time.
So what have we learned? We know that Pedders will be on this forum and in this community in good times and in bad. We know that mistakes happen and that Pedders sees to it they are corrected. Pedders honors our warranty and is committed to customer service. That doesn't mean it makes everyone happy. There are five in four years that are not. Would I like it to have been four -- absolutely.
If you choose to Pedderise your LX, know that you will recieve the best possible service from our Dealer Network with the support of Pedders corporate. Will you be satisfied with your Pedders bits and installation -- statistically the answer is yes. We are viturally perfect achieving 99.999%. The shame of it is we have failled at all in being perfect in this area. As I have done on this forum and others here is my mobile phone number 616.834.8100. Here is my office number 248.522.8021. Here is my email [email protected] If you have any issue wioth Pedders that cannot be resolved at the Dealer level feel free to call me.
First off let address the issue of my life being in danger. I said in my opinion, I felt that my life was put in danger. Pedders actually has a huge thread about "Dangerous OEM bushings", pedders thinks OEM bushing are dangerous but not a bolt with out a nut on it? Are you trying to say that not having a bolt on a nut is normal and isn't a big deal?
That is actually a very good point - and one I missed. For a company that throws 'safety' down your neck and trashes DCX for subframe bushes, a claim that a missing nut is 'no big deal' does kind of make me doubt aything that they say.....
Obviously the guys that check my car in Columbus didn't do a very good job if I had to take my car in again to get checked again. And if you think just because they did check my car that it makes us even, you are wrong. Pedders screwed my car up, so they needed to fix it. As for the Dynos, after I realized that my car had leaked tranny fluid I told you I didn't want to dyno it. You kept insisting that I get it on the dyno. It was your choice to dyno the car, not mine. I even offered to pay you and you turned me down.
So - we have a customer that does not find the free check as satisfactory compensation for their time and the problems encountered? Fair enough.
Please, any of you that might be considering Pedders, please PM me first. There was a lot more details to this whole matter that I chose to leave out due to forum rules. But trust me when I say this, it gets worse.
Also, you might want to keep an eye on this thread.
http://www.lxforums.com/board/showthread.php?t=121551
You/your outlet/workshop were lucky - plain and simple. You got away with a potentially far worse situation purely because somebody checked the work that had been done so poorly. The fact you are defending this workshop beggars belief.......
Whatever your excuses and mitigation leaving a nut off of a suspension system is dumb azz - plain and simple. That nut was there for a VERY GOOD REASON! If it were not necessary, don't you think that DCX would have omitted it?
Yesterday, I hoped upon hope that a Pedders rep wouldn't come onto the forum and start trying to claim that missing securing parts on a suspension system aren't that bigger deal if they are missing from certain places... Oh well - that's that down the drain.....
No true engineer would ever see something like that as trivial - or try and excuse it away as being 'not so bad'. It was a major c0ck-up and any intelligent person will know that......
And if I'd paid 5 grand for this poor standard of service, I'd certainly be expecting to be getting some of that back......
Dude - I now believe you are telling a much 'more honest' side to this story now, as I have just read this comment on the LX thread...:One other thing Pete forgot to mention was that I was nice enough to put my car on display at the Pedder's booth in Columbus. I had my car over there almost all day and actually stood over there and talked to a lot of people about how much I liked my Pedders and not mentioning anything about my issues with them. Did he ever once thank me for this? No. He almost acts like I owe him because his guys took 10 minutes out of their day to check the nuts on a car that their dealer screwed up that is covered under their warranty. How I see it, I actually did him a favor by letting him use my car for people to see and me actually recommending Pedders to people there.
To all those people at LX and Beyond that I recommend Pedders to, I am truly sorry that I recommend them.
What surprised me is the lashback on the LX forums. They are normally (for all the right reasons) the first to try and defend a vendor. However, I think Pete has made any kind of defense very difficult. Rob's trying, but to be honest, Pete has yanked the mat from under his feet.Thanks for the support arfur and to everyone else who has been supportive through all of this. I think most people on all the forums I've posted this on are on the same page as afur here and for some strange reason Pedders thinks it isn't a bad thing.
You are sooooooo out of line. Your car was not on display for Pedders. NO vendor would put your car on display - it is nasty! DIRTY! The inside is a wreck!One other thing Pete forgot to mention was that I was nice enough to put my car on display at the Pedder's booth in Columbus. I had my car over there almost all day and actually stood over there and talked to a lot of people about how much I liked my Pedders and not mentioning anything about my issues with them. Did he ever once thank me for this? No. He almost acts like I owe him because his guys took 10 minutes out of their day to check the nuts on a car that their dealer screwed up that is covered under their warranty. How I see it, I actually did him a favor by letting him use my car for people to see and me actually recommending Pedders to people there.
Couldn't have said it better myself.How many of us have had quality issues with our Dodge dealer, and this could be any number of them! Yet none of us, to my knoweldge, are subtly (or otherwise) knocking on corporate Dodge's door for renumeration from these bad dealer experiences. Why is Pedders any different? Ford used to advertise that 'Quality is Job 1', yet they never made payouts for bad dealership services.
i cant comment on ford cause i have never owned one, nor can anyone here LEGITAMENTLY search all records to see if labor or any funds were refunded due to crap service... lets be realistic. i am sure you can find a handful where this has occured...How many of us have had quality issues with our Dodge dealer, and this could be any number of them! Yet none of us, to my knoweldge, are subtly (or otherwise) knocking on corporate Dodge's door for renumeration from these bad dealer experiences. Why is Pedders any different? Ford used to advertise that 'Quality is Job 1', yet they never made payouts for bad dealership services.
