yes sir brad... those are the ones. up by the oem hood prop.
dag, as far as the clearcoat - i went with a clear coat all the way across the cover and the top pieces that we painted the 5.7 lettering....i covered it all with clear coat including the ram emblem to try and prevent any scratches....easier to fix clearcoat then paint....i was really worried about it though b/c some had said they had a fuzzy look....if you spray even and DONOT spray too much at a time you should be golden. just be careful...not telling you to go do it though...brad did you use a clear coat?????? or some type of top finish? my cans are probably floating but i used a duplicolor clear coat that made it all shine beautiful and didn't add any fuzziness. ask bstowers (aka brad) if he used a clear.....
