1 - 11 of 11 Posts
That dash kit replaces everything under that color change line except the far-most right hand part... The little strip just to the right of the glove box. That's actually part of the entire upper dash pad, so unless you wanna pay the $600 or so to get a whole new dash pad, you'll have to try your hand at dyeing it.
hmm thats unfortunate. anybody done this, bought the kit and left the piece tan. what dyes have people used to achieve the best color match
I think I'm gonna do this at the end of october. I'lllet ya know. If the bonus is big enough I'm doing engine work. If it isnt, I am doing interior and waiting till first of year for the engine
which is the part you painted i cant tell. is it the right part that would face the door, and would only be visible when the door is opened?
thankety. whats the kit run in total.
What piece did you paint, I can't even tell
Thats the point. :D
Its the soft dash pad piece, next to the glove box; on the right hand side. The piece by the door panel.
I SEM'd everything. But I do plan to atleast get the MPSC kick panel/lower pillar/sill panel trim; its not quite holding up to daily use. The door panels and dash pieces are still good, though.
hey Slow did ya do a write up, and if not maybe you could? I need to get crackin on what I CAN get done soon, now that the weather has cooled down some.
No write up; but Ive explained it about a dozen times in PM's. :)
Check 1 Badass R/T's thread in the interior section; hes the one that I helped the most. The biggest thing is prep prep prep.
A local paint/body supply store should have SEM. They have a HUGE book with a million swatches; and each has a hole in the middle; so matching colors is absolutle brainless. I also reccomend the 'low luster clear'. It helps protect the paint without adding shine. Total cost of the parts; well I dont remeber but Badass R/T should as hes done it recently.
The drives side of my car has help up much better than the pass side (thanks wifey) and the rear...well with 2 kids and car seats; has seen better days. Thats why I plan to order the MPSC kit for the lower pieces soon.
Regfular rubbing alcohol is best (from what I was told) as other harsher chemicals will stay inside the material; and relesase over time and cause bubbling.
1 - 11 of 11 Posts
