1 - 20 of 28 Posts
Hello all,
Figured I'd share my experience with this kit. It is sold directly by Mopar (and most online or brick and mortar dealers are able to order it) and it is the Bilstein shocks with Mopar lowering springs. The kit comes with 95% of the items you need, with the only thing being reused is the front shock mounts and dust boot. I ordered these new just so every piece going in was a 0-mile item.
The Kit:
2016 DODGE CHARGER Mopar Performance Suspension Upgrade Packages P5155435AD - Free Shipping on Orders Over $99 at Summit Racing
The whole thing goes for the low $600s, but Summit can price match you with an online Mopar dealer. I had them price match East Coast Moparts as they had it for $513. They also offered free shipping, which was a plus. This kit should fit any 2006 and up Dodge Charger/Challenger/300 in V6 and R/T trims, but please note that earlier models may need some adjusting or work for proper fitment and drop height. The drop height is slightly more on the V6 models over the stock R/T height. My 2016 R/T went down just over 1" all around over stock.
If you need the part numbers for the boot and upper mounts, please let me know. I have them in my email.
Installation:
The cost of installing can vary widely. It is about a 2 to 3 hours job, so a dealer may charge upwards of $400 to do this. I had a local shop do the whole thing for $200 wheels up to wheels down. It was another $50 to have the car aligned.
While I won't dive into the installation process too much, it's all pretty straight forward. The rear involves removing the 2 bolts at the top of the strut as well as one on the bottom connecting to the control arm. It can then be pushed down and slid out. For the rear springs, the instructions state to drop the rear cradle. However, we simply removed the bolt connecting the control arm to the cradle and dropped it enough to get the spring out. Then, it was just going back in the steps and tightening it all up.
For the front, you remove the 3 bolts on the shock mount (under the hood) and one on the bottom of the shock connecting to the control arm. If you're lucky, you can wiggle the assembly out and the new one in. In most cases, however, you will have to unbolt the upper control arm and separate it in order to drop the suspension low enough to get the assembly out. Other than that, reverse the steps and tighten everything to spec.
Once the suspension settled, the alignment wasn't all that far off. I had purchased a pair of SPC adjustable upper control arms (for the front) in case the steering was off wack. However, these will be going back to Summit as the front was just marginally off from what it originally was. It took 2 minutes for my alignment guy to get the front and rear back to spec. Please note that the rear of my car already had SPC bushings for adjusting camber, so the rear may or may not be good to go and you may or may not need those bushings to get it where it should be.
Pics:
While I don't have any before pictures, as the excitement of getting it all in got the best of me, I can show you the after. After these pictures were taken, it settled just a bit more, maybe about 1/8" or so from what you see here. The car sits much more flush to the wheels and the wheel gap is pretty much gone. I can no longer see the upper parts of my suspension from just looking at the car from the side.
How It Performs:
It is a night and day difference over the stock "Sport" R/T suspension. I'd imagine that this would be an even bigger change for V6 suspension. The car has lost tons of body roll, on the corners it remains flat, and the steering feels more responsive. There is a tight S turn here in my area that I used to take at about 60MPH with some light tire squeal and I was able to take it at 74MPH after the new suspension with no tire noise and without pushing the car too hard. Also, launching it from a dig feels more planted, the rear seems to stick more, and it doesn't feel as squiggly as it did before.
On the highway, it is smooth as butter. While you do feel bumps and road damage a bit more, it is a marginal difference and I feel I like the quick bump over road imperfections over the bump and subsequent wobble and bounce my old suspension had. At higher speeds, the car feels planted and stable and switching lanes abruptly it's flat and precise. Previously, any sudden lane changes came with tons of body roll and the feeling of being unstable.
All in all, for well under $1,000 installed and aligned, I'd say it's well-worth it. While I know that coilovers would net better performance, I didn't want to meddle with adjusting things and any alignment issues I may face. These feel more forgiving in city driving and I'm not worried about bottoming out the car in any driveways or rough roads, even with my long tube headers.
Feel free to ask any questions. I'll answer them as best I can!
Reactions: RT-G2
I've been thinking about getting a new suspension but wasn't exactly sure which ones to get. I have an 06 r/t and I was wondering if you knew what differences there would be in installation. I just get weary when any site says it doesn't fit my model.
Sent from my SM-G965U using Tapatalk
From what I'm reading, this is all you need for it to fit just fine:
"All that is required for an 05-10 fitment is a few washers at the bottom of the front strut mounts and a longer bolt for that location. Otherwise, it's bolt on and go."
Reactions: TheBearddBastrd
I'm surprised you were able to get the kit, they've been on back order for a year...( I tried three places to get a kit for my 2013 before it was totaled)
I considered the kit in 2016 for my 2008 R/T, but I, too, had issues getting a hold of it. It was sold out everywhere I looked with no date set on when inventory would be replenished. I then revisited the kit after I got my 16 R/T in February of this year, but the dealer stated there were SEVEN available nationwide with a long list of orders waiting to be fulfilled. I almost went with an Eibach kit until I saw Summit had them. I sat on the idea for a few weeks, and the availability fluctuated from 1 to 2 weeks shipping time to shipping as soon as same day. Maybe Summit has the entire stash of these kits to themselves? They're still available for shipping same day as I type this...
The nationwide backorder must be over. I ordered mine in August and it's been sitting in my garage for a couple of weeks now.
Does anyone know if this kit is compatible with AWD? When I research suspension kits and plug in my cars specs sometimes I am told there are no kits compatible with my car when I select AWD drivetrain. Thanks!
You don't mention what year your car is, but you can ask your local Dodge parts department to contact Mopar performance tech support, and they can verify the application for you.
My guess is that the Bilstein shocks and struts would likely fit, but I don't think you'd be able to use the springs.
2012 SRT Charger, 2003 Ram hemi, 2005 Magnum
Definitely not. Front suspension is VERY different between AWD & RWD. For example:
After install of this system,...you will need the front adjustable arms to correct camber/caster. On mine, camber is out by .1 but the caster is out by a much lager .7-1 degree. Your going to wear the insides of the tires. Other then that, I agree with the OP. It's a good upgrade.
Hi, i was just reading the posts and i got a question, and is if this kit is adjustable or is just to drop the height of the car only???
I have a ‘17 charger SE and the desires for some upgrades to it.
It's not adjustable.
But you can keep your original springs and install the rest of the kit, if you want to keep your stock ride height.
But i dont know if im right or wrong but doesnt the SRT models have the super trackpack suspension on them and haVe the option for adjustable height like an adjustable suspension???
Or that is a another completely different feature on the SRT models???
"Super Track Pack Kit" is a misnomer. Installing this kit will NOT give you all the features of a factory STP car. There is zero adjustability.
Mopar doesn't even market this with the title "Super Track Pack", although dealers usually do.
It's just a spring, shock & bushing package, you can easily see the included parts in online photos.
For adjustable height you need either a spring adjustable for height with a threaded sleeve going up or down
or air bags that inflate/deflate to raise/lower the car.
My post was related to keeping the swaybar level by compensating for static ride height.
2016 Charger R/T, Jazz Blue
Hi, hopefully this thread isn't dead? New member here, but was wondering if I could replace the springs in this kit with those from Eibach or another third party. Would they play well together w/the Mopar super track pack upgrade? I'm looking to lower and get some 22x9's (maybe staggered) to mine and was looking into this upgrade or one of the other kits (shocks, springs, sway bars, etc...) available. I'm still looking to stay under warranty too... Thanks for any info!
I didn't see anywhere from the OP what size tires and wheels he was running. I'm looking at adding this kit but want to keep my stock 20 X 8 wheels and 255/45/20 tires. Will it all work without rubbing using this size tires and wheels with the 1 or 1.5" drop the new springs give you?
1 - 20 of 28 Posts
