I was looking for ways to mount my cell phone for use while driving. The Charger has an odd shaped windshield which makes it difficult. I looked at vent mounts as well but the vents on the charger had the adjustment piece right in the middle. I ended up going with a mount that I bought at Best Buy which works perfectly. The suction mount is a soft pliable rubber that is designed to mount on the dash. I've not even tried that as I mounted it right next to the gear shift. Works perfectly. It won't come loose, it will pull up the interior piece before it lets go. While it would be a little better to have it mounted higher up, this works (at least for me) just fine It is also right next to the power port in case you want to charge and the wires won't get in the way (and will be hidden). I've included a photo and link in case anyone wants to consider.
The mount and phone does not interfere with the gear shift at all and it does not get into the way when reaching for it either. The photo is a little deceiving.
https://www.bestbuy.com/site/bracketron-slydelock-dash-mount-with-charger-for-most-smartphones-black/5777000.p?skuId=5777000
