I discovered some new things on my '08 R/T:
1. In Fuel Saver mode, the letters 'FS' shows at the top left corner of EVIC temp display. I asked around and people said this was not in the '07s.
2. I was travelling at 87mph on the freeway and if I kept my foot on the gas pedal steady, 'FS' would show on my temp display. I searched through some old posts and read that MDS was not active at high speeds.
Addendum: This is not new in '08s. Sorry for the wrong info. I didn't read enough. MDS is dependent on many things but not limited to a certain speed.
3. My fuse box up front is different that previous models. There's a lot fewer fuses. The fuse 11 on 05-07s is now fuse 2 on mine.
It's not exclusively a speed issue... I think it's all about the PCM calculated load. That means it'll be a function of MAP, air temperature, pedal position, etc. Put your EVIC in diag mode and look at the pedal positions necessary to get MDS to kick in at those speeds: my guess is that it'll hold MDS until 25% or so, but probably not on an incline with the car slowing down.
I've had MDS on at an 85 MPH cruise with 4 people in the car but it was damned cold that morning! (ie. really dense air).
That's pretty cool, so it tells you that you are saving gas. The should add WOT on the EVIC for us spirited drivers :grin:
