1 - 20 of 26 Posts
Has anyone ever thought about asking a company like Diablo, to make a simple tuner to turn "OFF" MDS only?
I ask because I have read many post about MDS only questions. Yes. we can use auto stick and shift but that is a hassle, as I have a police column shifter. I would like a car to shift automatically by itself like the old ones did. All this retuning is confusing and in my case not needed. I just want the Hemi sound from a Hemi, from idle to full throttle. Is that too much to ask??
BTW, I am installing a cat-back system and air kit. I am not going to race as I am 66 yrs old and set in my ways.
Question: What sounds better than a wide open Hemi????
I believe you can turn it off with a handheld tuner... not super familiar with those as I use HPTuners.
You could also visit any shop that tunes with HPTuners and they can shut it off for you no problem with a custom tune. They can do just that if you don’t want anything else done.
Sharpe:
Welcome to the forum!
I prefer to keep my cars pretty much oem, so mods are rare. The MDS does not bother me one way or the other, but it would be nice if they would have given us a switch, even if I had to cycle it with every trip.
Don
Do all the different companies do MDS the same way? Essentially starving the valve train of oil if I understand correctly? Every time that system kicks on and off is extra wear. No thanks.
I disliked mds on my challenger and my charger. The exhaust note change/vibration was enough to make me want to get it turned off in the first week of owning my charger.
If it weren't for the vibration and slight hesitation when it turns off, I wouldn't mind MDS on wife's RT. But, she doesn't want a tune and I don't want to pay that kind of money just to turn it off. So, yes, just enough of a tuner to turn it off would be helpful.
There is a (*) on the "Safe and Reliable" Tab describing the MDS Manager that says its not available for engines with push start. So I dunno if it would work. Anyone have one that can verify one way or the other?
MDS Manager - Range Technology
Discussion Starter #10
I have sent an email about it and will update when they respond
Discussion Starter #11
Just spoke to a Tech from Range and here is the scoop.
This MDS Manager works on our cars up to 2011 with "key" start. They are working on a new one for 2012 and up, but not yet available.
At least someone is working to help us.
I don't really have an issue with the MDS to the point of doing something about it. I like to keep my cars pretty much stock as well. I'm not a fan of cylinder deactivation, and even less of a fan of the auto shutoff/on when you come to a stop light or are sitting in traffic. It was all done by manufactures to try and squeeze out better MPG to comply with federal regulations. Thanfully those have been relaxed a bit.
I don't know the mechanics behind it but read that newer GM systems do not always shut off the same cylinders. They vary the cylinders, and I'm guessing to spread out the wear.
It seems like no matter who does it that every system deactivates the valves. I'm presuming they also shut off the fuel but have never seen that mentioned.
If the deactivated valves are closed doesn't that mean the piston is always working against compression? IOW 4 cylinders are providing engine braking?
The injectors are not active on the inactive cylinders. The cylinders affected by MDS are in the compression mode and they function like a spring compressing and expanding with engine rotation.
MDS does not create any additional wear. Valve train still gets same oil as before. Only when MDS is active higher pressure oil is fed to a specic part in the lifter to allow it to collapse. MDS has been around in the GEN III Hemi for a very long time without overall massive issues.
That being said, There are products that can turn MDS off. I just suggest getting a tuner to do it so you can get the added benefits of little extra power.
Discussion Starter #17
A new question for yall. I have read other post in the forums. Some people have replaced the cam and lifters and no longer have MDS. Did they have to retune the engine after rebuild?
Have to tell the computer to disable the MDS system so yes.
Also, You can not properly run non mds lifters on a MDS camshaft even though there is few that say you can.
I was wrong about mine thinking that it only worked in "ECO" mode. I drive mine all the time in "STREET" mode, and see that it does go into 4 cyl mode at times. The confusion is that I only notice the noise/drone issue while in ECO mode, and no weird noises in STREET .
Hi Wisconsin Bob, Sorry to hear you are experiencing this concern, we certainly understand why this would be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support.
Rob
DodgeCares
1 - 20 of 26 Posts
