1 - 2 of 2 Posts
06 SXT with ESP and std. brakes solid rear rotors. Single pistion calipers
I needed a master cylinder so I ordered one and the one that came had a 3rd brake line and mine only had the 2 lines leaving the master cylinder so I sent it back and they sent me the one for no EPS and it looked exact so I figured they messed up the part numbers. But the no EPS master has different size ports that are 12mm by 1mm pitch. My brake lines in the car are larger then that. One site I looked at they had a master that has 14mm by 1.5mm pitch for outlet ports but it does not say whether it has the 3rd line or just the 2.
My question is what is that 3rd line for. most of the pictures on the sites show that with ESP it has 3 lines.
Thanks
My first thought and guess is that a 3rd brake line would be for ABS maybe?
I don't think V6 models come with any type of ABS
(ABS is Assisted Braking System I believe and is not the same as ESP which is Electronic Stability Control)
Did you use your VIN number when ordering the part?
1 - 2 of 2 Posts
