So I just got my car back from the dealership service department after giving it to them for a 85 point inspection and am now faced with dropping a lot of cash because they are pretty much the only people I would trust with my car. Anyways here is what they told me I needed:
Brake system flush: $99.95
Power steering flush: $103.99
Front pads and rotors: $538.11
Rear pads and rotors: $592.89
Front sway bar bushings: $98.04
All including parts and labour. Unfortunately I don't have a money tree in the backyard so I refuse to pay close to $1600 most of which will be because of OEM parts. I thought since I was getting all this work done I might as well get everything done that I can. Here is what else I will be getting:
Replace air conditioning filter: $28.00 part $34.50 labour
Replace spark plugs: $98.56 part $253.00 labour
Change engine and oil filter: $35.75 part $12.00 labour
Flush and replace engine coolant: $59.25 part $92.00 labour
Change automatic tranny fluid and filter: $134.74 part $115.00 labour
Drain and refill rear axle fluid: $70.50 part $80.50 labour
Due to a couple of unexpected events for which I've had to pay large amounts of money I doubt I can afford all that with the dealerships crazy prices. So I've decided to put aftermarket parts on which will dramatically reduce the prices. So finally here is my point, I have been snooping around on here and checking out aftermarket parts from the vendors and parts that other members have installed and need help from all you guys to find the best parts so I can get everything done. If you guys have any aftermarket parts that you like and use please let me know. These are the following aftermarket parts I will need:
Front and rear brakes and rotors (I've heard R1 has good rotors and the Posi Quiet pads)
Engine Oil & Filter (Deciding between Mopar or Royal Purple)
Spark plugs (No idea)
CAI (Currently have an Aria that the previous owner installed but I might be interested in a new one, maybe K&N or AEM)
If you guys think I could save some money and get the same or even better performance from after market parts or even if I could buy some fluids myself to save the money please let me know.
Also depending on how much money I save I want to install a 180 Tstat, Oil catch can and halo lights. Opinions and reviews would help for those as well.
Sorry for all the reading Thanks
