AllUSA Motorsports is happy to offer 2 new differential swaps kits for the LX cars. The 3.73 and 3.92 LSD from the 2009 Challenger.
Upgrade your stock axles to the new larger axles and 226mm limited slip differential from Mopar. Our kits ues OEM 2009 Challenger SRT-8 Axle Shafts, Hubs, and Differential. This kit is designed using OEM parts to upgrade your LX non STR-8 to use the new Challenger SRT-8 axles, hubs and limited slip differential.
Kit is designed to fit the following vehicles:
2005-2008 Chrysler 300, Dodge Magnum, Dodge Charger
Features
1 OEM LH Axle PT# 4578733AB
1 OEM RH Axle PT# 4578732AC
2 OEM Hubs PT# 4779572AA
1 OEM 226 mm 3.92 Limited Slip Rear Differential PT# 5038237AD or PT#4593854AD 3.73 LSD.
3.92 Kit PT# LXDRD392 Mopar List $3610.00 AllUSA Price $2702.31
3.73 Kit PT# LXDRD373 Mopar List $1905.00 AllUSA Price $1412.53
All prices are plus shipping.
will these setups work for us v6 guys? and do we have to swap out the axles and hubs or can we use our oem one's and just change the diff?
We have never done this swap on a V-6 so I am not sure what all would be involved. I will need to do some research on this.
Jeff
Would these fit and work in an SRT-8, and what, if any, type of programmer is required to make this work?
This kit will work in a SRT-8. You need to get the our drive shaft package or a 5.7L drive shaft to complete the install. You will need a Diablo programmer to set your rear gear ratio.
Jeff
