1 - 8 of 8 Posts
So i wanted to lower my r/t max, i saw some eicbach lowering springs for $276, ( http://www.autoanything.com/suspension-systems/61A2549A0A0.aspx )
will that work? Will i need to do anything after?
Is 1 inch/ 1.5 inch, low enough? i dont want it super low, but just a bit for better handling and just so it doesnt look so high.
I believe with the rt max you have the self leveling nivomats in the rear. From what I've read there are issues with just replacing the springs. You'd have to replace the shocks as well. I have an awd rt max and I put on the BC racing coilovers in January. Pretty happy with it so far. I believe the best way to go is coilovers.
2014 phantom black rt max
Thats all you need, but a camber kit is recommended. I have the prokit on my 13 R/T.
You need to change out the Nivomat shocks in the rear if you have them. Eibach also makes a camber kit that can be installed at the same time as your springs/shocks.
· Premium Member
Charger RT
^^^What they say about the shocks. I put on the kit and the ride lowered around 1 1/4 inch. Highly recommend two alignments. One just after install and one after the car has a few thousand miles.
1 - 8 of 8 Posts
