1 - 20 of 23 Posts
hey guys i was wondering if any of you guys are having a knock comin from the front suspension.. well my problem is that everytime i go through speed bumps or through small pot whole i hear this loud knock coming from the left front suspension.. i just changed my front shocks like 2 months ago under warranty cause they were leaking and i dont think that is the problem.. what else do you guys think it can be.. i want to get it fix asap because i will be lowering my car this labor day.. can it be the control arms or the spring being loose or somethin.. any help would be appreciate it.
More than likely, it's the nut that's on top of the shock, right in the center (accessed underneath the hood). You need to get that nut tight and torqued to spec or it will cause what you describe. To do that, you need an offset wrench. If the dealer did your new install, simply take it back to them. Or, check that nut yourself and, if you have the right tools, tighten it.
I had the same problem on the right side. It was the top bolt on the shock. I just tighten it up, no problems
bend down by your tire and say "who's there"
orange
orange who?
orange you glad i'm not plum crazy????
thats exactly what i was thinkin.. i guess i will tighten it tomorrow morning since ill be here at work all night. and if that dont work ill just take it in to the dealer... thanks alot guys.. yall :rockon:
Suspended User
im having the same problem on that front left side. i just installed eibachs about a month ago but dont have time right now to pull it out! i hate it though!
i havent got a chance to tighten it up since ive been busy everyday.. im really hopin if i tighten up that screw it will go away.. it gets so annoyin everyday i go over the train tracks.. and its not my fender catchin to anything.. so i know its not that... can it also be the bushings on the control arms or somethin..
Well i'm having a problem but it sounds like something is twisting wen i break hard......Told the dealer and they didn't know wat it was, they find anything so i wondering if anyone mould about that?
i have also had that noise but it goes away here and there.. i also took it to the dealer for that but they said everything was fine..
You need to take 2 minutes and check/tighten that top/center nut on the front shock. If that's not it, let us know. I bet that it is.
Discussion Starter · #16 ·
i checked it earlier with my fingers of course since im at work.. it doesnt seem to be loose.. but i think i will be up late so i can tighten it up a bit
LOL, you can't tighten (or check for that matter) that nut with your fingers. It's tight right from the start, but it will continue down the threads until it really tightens to the point that it needs to. Get an offset wrench and start turning.
Discussion Starter · #19 ·
I for sure thought it would be your tire catching your fender. Oh well
thanks by the way bro.. i also thought that at first...
well i'm not sure wat to do wit it? and also wen i hit pot holes or da old school speed bumps, my steering wheel gets uncontrollable and my brake goes all the way in. Has anyone delt wit that before? or heard anything bout it? the dealers are turning out to b a little useless now.
1 - 20 of 23 Posts
