Ok, first off, your car came with 2.75" exhaust, why would you use a smaller pipe?
Secondly, get ready for drone. The rear resosnators are designed and tuned to reduce cabin drone. You're about to be in for an annoying ride.
Lastly, your ears have mis- calibrated your butt-dyno. You're hearing a LOT of noise and THINKING you should be faster, when in fact, you're accelerating at the exact same rate.
The mufflers and resos on an SP are straight through. There's no restriction, so removing them doesn't create enough airflow change to make even a 2-3 lb/ft of torque difference. You'd never be able to tell the difference.
I've had about 6 different exhaust set ups on my 17 Charger SP. None of which has changed my track times or 0-60 times. The extra sound does make you feel like you're slower though.
The last set up on my car was to add mufflers the same design as the factory ones to my car (which was straight-piped to the resos). The change did make it seem like I had lost a little but she's still 0-60 in 3 seconds and 1/4 mile in low 10's. No loss of power, the sound just confused the feel.
