Thinking about going with the CORSA CAI, I have held off on getting one as they really do not add much in the way of HP/TQ but they do spruce up the engine bay a bit. So just wondering if anyone here has any experience with them.
http://www.chargerforums.com/forums/showthread.php?t=157088I had an LMI True CAI on my 08 R/T and it was awesome. So because of past experience with LMI I am going that route, but Im like you Im not drilling on this baby!
You can just make your own for around $75.Yeah I noticed it was similar to the Volant CAI kit. Really debating if I want to drop the cash for one or not when the gains just aren't there, but there isn't a tube made to replace the stock corrugated tube and it seems a CAI kit is the only way to do it. The stock box itself is very efficient but the stock tube cause some turbulence in the air flow being corrugated.
This looks great, but will it work for the 5.7L? Are the intake hose sizes the same?You can just make your own for around $75.
http://www.chargerforums.com/forums/showthread.php?t=115086&highlight=srt+airtube+mod
You can do it for the 5.7L, you just need to buy the couplers in the correct sizes. See the thread I linked for sourcing the parts.This looks great, but will it work for the 5.7L? Are the intake hose sizes the same?
I can't, I tried. Not one company makes a tube that will work with the canted 392 intake. The angles are all wrong, they are either too angled or not angled enough and no one will custom make me one. The tube has to be made specifically for the intake and the only ones that are right come with CAI kits.You can just make your own for around $75.
Well you can, but you need to have the tube custom bent (just like bending exhaust tubing). You need to buy a straight tube long enough for bending and then get a shop to bend it to your angles and cut to length.I can't, I tried. Not one company makes a tube that will work with the canted 392 intake. The angles are all wrong, they are either too angled or not angled enough and no one will custom make me one. The tube has to be made specifically for the intake and the only ones that are right come with CAI kits.
PM me with the details and I'm sure we can find a solution.That sounds great, it was more the rubber hoses that were not the correct angles and I tried the bump hose too. I tried 5 different companies on the internet that make hoses for DIY CAI and running intercoolers and no luck. It isn't the straight aluminum tube that's the problem, I found one that would work great if I could find the rubber hose angled right to connect it to the intake manifold. I'll take any help you are willing to give.
Ok will do.PM me with the details and I'm sure we can find a solution.![]()
Take a look at the two different air cleaners in these photos of my 513 cube stroker...the 3.5" tall filter makes 20 more horsepower than the High Performance "Unsilenced" 2.75" tall filterNever heard of Donaldson before. Plus I don't think a huge filter surface area is gonna make but so much difference. The throttle body will only flow but so much air as well as the tube leading to it.
So you dynode an extra 20hp out of a filter? That sounds a little much, I'm not saying I don't believe it don't misunderstand that but every CAI company out there uses a larger surface area filter than the stock configuration and they make claims of 20plus HP and no one I have heard of has seen that kind of increase, usually its more like 5hp if you are lucky. Now LMI's true CAI saw like 10hp increase but that's the most I have seen. I dynode my 08 R/T after I installed a CAI kit and saw 0 HP and 0 TQ increase from baseline. Now on a stroker motor you may see a better return for the simple fact of the modifications to the engine, but stock I don't think 20hp is there. Question, what kind of car is that stroker in by chance?Take a look at the two different air cleaners in these photos of my 513 cube stroker...the 3.5" tall filter makes 20 more horsepower than the High Performance "Unsilenced" 2.75" tall filter
When you are making 520+ horsepower, 20 more ponies isn't that much...less than 2.5%. The filter area is much greater in the tall filter, but I think it probably has more to do with the design of the air cleaner itself...the little "unrestricted" air cleaner only has 1/2" of clearance between the filter and the housing, and it pulls hot air up off the engine. The big dual snorkel air cleaner has 3" of space between the filter and housing, and it is getting slightly cooler air coming in from the grille.So you dynode an extra 20hp out of a filter? That sounds a little much, I'm not saying I don't believe it don't misunderstand that but every CAI company out there uses a larger surface area filter than the stock configuration and they make claims of 20plus HP and no one I have heard of has seen that kind of increase, usually its more like 5hp if you are lucky. Now LMI's true CAI saw like 10hp increase but that's the most I have seen. I dynode my 08 R/T after I installed a CAI kit and saw 0 HP and 0 TQ increase from baseline. Now on a stroker motor you may see a better return for the simple fact of the modifications to the engine, but stock I don't think 20hp is there. Question, what kind of car is that stroker in by chance?
