I just purchased a 2009 charger srt.On the list off components it says limited slip rear end.Did it just start on the 09 models.I tried to look it up on the internet with no luck.Does anybody know ,,,,,,
Yes, new for '09. I bought one for my '07. The '09 SRTs also have stronger halfshafts. Lucky you!I just purchased a 2009 charger srt.On the list off components it says limited slip rear end.Did it just start on the 09 models.I tried to look it up on the internet with no luck.Does anybody know ,,,,,,
yes... must be nice:cowsmile:Yes, new for '09. I bought one for my '07. The '09 SRTs also have stronger halfshafts. Lucky you!
Well, I'm not trying to burst your bubble, but I hope you can launch better than I. I've had nothing but troubles trying to get the car moving. Give it a shot, and report back, I'm eager to hear your experience.Is it the getrag 226 lsd.,sweet. I wonder if it will improve the launch .Can't hurt for sure.
What are your 0 to 60 times.I'm in edmonton so same conditions and elevation.I got a 5.68 with 550 km ,26c outside stock no predator no 180 thermo.Loaded the torque to 1500,no wheelspin?????I will put more km on then load the 91 tune and get a 180 stat..Well, I'm not trying to burst your bubble, but I hope you can launch better than I. I've had nothing but troubles trying to get the car moving. Give it a shot, and report back, I'm eager to hear your experience.
Consider when you are ready the QuantumBlue 12.5w40 High Performance Competition Formula. Also the ACES IV Gasoline Formula Fuel Catalyst.What are your 0 to 60 times.I'm in edmonton so same conditions and elevation.I got a 5.68 with 550 km ,26c outside stock no predator no 180 thermo.Loaded the torque to 1500,no wheelspin?????I will put more km on then load the 91 tune and get a 180 stat..
Grimlock,No clue what fuel addatives have to do with LSD....
But, yes the LSD will give you the greatest advantage accelerating out of corners. The best way to feel to work is to exit a parking lot or road and turn left on a road with 4 lanes (2 each way). If you did this accelerating brisky in a non-LSD car you would light up the one tire and have traction control kick in, and this was *SUPER* annoying to me. Thats why I bought a Quaife, and it cured it 100%.
I doubt that LSD will help your 0-60 times, other than runs on gravel roads. The stronger rear end might help in the long run though!
We have limited slip diff's and beefier half shafts on the 09'sSo these cars used to have a brake-lock diff?
I thought the SRT engineers were all about the BLD's, saying they were better than an LSD (at least that was what they said about the Caliber)
Are 2009 SuperBees included in this 'lucky' bunch of cars with LSD's and tougher half shafts?
How can you confirm if you have this stuff or not?
did you install your LSD or have a shop do it?No clue what fuel addatives have to do with LSD....
Elevation is actually quite different (2200 vs. 3400), especially considering DA. Last Friday at the track DA was close to 5500 ft. I haven't done any 0-60 times (maybe I'll try some tomorrow), but my 1/4 (EVIC) times are about as poor as my times at the track, along with my trap speeds being 5-7 mph slow.What are your 0 to 60 times.I'm in edmonton so same conditions and elevation.I got a 5.68 with 550 km ,26c outside stock no predator no 180 thermo.Loaded the torque to 1500,no wheelspin?????I will put more km on then load the 91 tune and get a 180 stat..
I had a shop do it. This is NOT a do it yourself job. It takes special tools and experience to get it right. I drover 2.5 hours to go to a shop that had done it before in a SRT8.did you install your LSD or have a shop do it?
thanks for the info...:beerchug:I had a shop do it. This is NOT a do it yourself job. It takes special tools and experience to get it right. I drover 2.5 hours to go to a shop that had done it before in a SRT8.
The good news is the Quaife has a lifetime warranty.
Yes, they used to. They said it was better probably because.....it was cheaper.So these cars used to have a brake-lock diff?
Is there a thread on this forum that does not get hijacked by a sales pitch???Consider when you are ready the QuantumBlue 12.5w40 High Performance Competition Formula. Also the ACES IV Gasoline Formula Fuel Catalyst.
Both will protect the inside of the engine and give you better throttle response, quiet the ticking and give you more power and fuel economy. They are great companions to the Predator as far as performance.:driving:
Nope. You should drink the stuff too. You will lose 30lbs in 10 days!Is there a thread on this forum that does not get hijacked by a sales pitch???
BINGO!No clue what fuel addatives have to do with LSD....
