Hey guys,
I was hoping one of you would have had some experience on a particular issue I have been having. I drive a 2008 dodge Charger R/T AWD with the 5.7 Hemi (180,000 KMS). My issue is that it appears to have intermittent lifter tapping and it has become a rather annoying issue. I have been to the shop and have tried changing my oil, doing an engine flush, and even attempting the long shot of using seafoam. I will be the first to admit my understanding of automotive parts or theory is not my strong suit. I have just been going on what my mechanics have told me. My main mechanic (close friend) has been working with me trying to avoid what I believe may be the inevitable of having to replace all my lifters ($1500 repair). I have had two different mechanic friends look into my car and the thing that has them trying alternative fix solutions is that once I go onto the highway (I.E RPM's past 2000) my lifter taping will go away and tends to stay away until I do an hour or two of in town driving (lower RPM's). whats really odd is that even with the occasional drive around town my lifter tap will once again go away even operating at low RPM's. My second mechanic friend has just recently looked into my issue and says that I should even try a thicker oil. His thought is that since my issue goes away when driving my car at higher RPM's causing more pressure to push the oil through, that I should try and use the thicker oil creating the same effect at lower RPM's. I know that dodge suggests only using 5w-20 but I have also read of people going to 5w-30 in their chargers with no side effects
Anyways, Im wondering if you guys have had this issue or if you have any thoughts on this matter. Do you think I should just go ahead with a lifter repair or should I still seek other possible fixes? does this intermittent effect sound out of the regular for a typical faulty lifter replacement? I have been told that the tapping or ticking is not causing any damage and that it is just an annoyance more then anything. Lucas oil stabilizer is another thing I was told I should try.
I will upload the video of my lifters tick I took a few weeks ago. I just took this second video an it appears to have a little bit of the noise still but its drastically reduced. This is 24 hours since my last trip on the highway so the noise will start creeping back up to full potential. Usually after a week or so of no highway driving my tick can actually be even louder then the first one. Hopefully this all helps. let me know if more info is needed
Derek
Lifter tick https://www.youtube.com/watch?v=dIEI58riWpY&feature=youtu.be
No tick https://www.youtube.com/watch?v=2QD3_SKR4dU&feature=youtu.be
Derek
