1 - 4 of 4 Posts
Howdy,
I was looking to have my interior lights all done as LED lights, but since I just got my 2014 Dodge Charger R/T, I am a bit hesitant.
Only reason is the removal of the covers or panels to get at the bulbs. My 1993 Dodge Intrepid ES it was pretty straight forward when I did it. It was basically a black screw on the panel for a small notch on the clear plastic cover or lens. Looking at the inside, it would appear that the design is a bit less owner friendly in modifying or replacing the bulbs.
Question is, is there any diagrams on how to get to the bulbs without making a mess and damaging my interior of the car?
Also, will these need the LED resistors/converters or not?
I am looking to get my bulbs from diode dynamics online, and not seeing they offer the converters or resistors.
Thank you in advance.
Not of the interior lights require resistors. The over head console is held in by tabs. They’re snug but get a trim tool and pry down. There’s little access doors for the lights. As for the other interior lights YouTube it and should find the help ya need
If anyone wants REALLY bright LED lights with good warm color for the overhead console, try these from Lowes:
https://www.lowes.com/pd/Kichler-25-W-Equivalent-Warm-White-T4-LED-Landscape-Light-Bulb/1000195089
Remove the glass cover from the outside. They fit well, and it's like having an area light in the car. I did the one on the passenger side only so that I can pop the driver side with normal 5 watt w5w light that's in there, and floodlight on the passenger side lights if I open the door, or manually turn it on. They claim it's equivalent to a 25 watt bulb. 210 lumens vs. 50 lumens for the incandescent.
Consider Xenondepot.com
I have spent a very good chunk of change, time & research to replace all of my interior bulbs to LED's on my 2012 Charger Blacktop....pretty much plug & play with a few simple tools & 'soft hands' to get the job done.:bigthumb:
My primary source is www.xenondepot.com (which lists the bulbs you need in very detailed way....also confirm with your owners manual).
There is a vendor here - Diode dynamics - (I can only speak from personal experience) but have found them to be simply inferior with similar products they offer, extremely disappointed with their (lack of) customer service & overall I personally would not recommend them...I personally will not do business with them again.
Good Luck!
:beerchug:
1 - 4 of 4 Posts
