.....From what I've researched it's almost as if putting a non-reflective license plate cover over your license plate.....
So, useless, and ineffective? A myth that people think works?
Seriously, the anti-reflective tape doesn't do any good. We aim for the plate because it's central, and easy to aim at, but the bumper, headlight/tailight, hood/trunk, etc work just as well.
Not to mention Ohio (and likely other states too) specifically prohibit the use of it.
..... I also repeat I am NOT getting this to break the law......
Just giving you a hard time, but in all fairness you ARE getting it to break the law. Speeding is breaking the law, even if it's only 3 mph over the limit. If you never exceed the limit the detector/jammer is a waste of money. Buying one if you don't intend to speed, is like buying a parka, and saying you don't go out in the cold. Why would you buy a coat if you will never wear it, and why would you buy a detector/jammer if you will never speed? I'm just busting your chops man, I knew what you meant. You don't intend to drive like a crazy person. I just saw humor in the wording, and had to give you a hard time about it. >
:beerchug: All in fun, no offense.
......Often times it will result in a ticket being issued to you just because you went out of your way to avoid getting pulled over for your driving rather than changing your driving habits.......
Very strong possibility of this. The reason for issuing warning or citations is to affect a change in behavior. If you have a detector/jammer, it's a pretty clear indication of intent to speed. Even if you don't intent to drive outrageously fast, it's still like telling a cop that issuing a warning will be ineffective.
Also as the others have said. In most areas, other than the interstate, lidar isn't used too much. The problem is we've got to be stationary to use it, so some guys don't bother with it. Radar, which can be used mobile, is used a lot more often. I personally like lidar better but I don't do a whole lot of speed enforcement, or work the interstate very much, so even I don't use it that often.
One other thing to add, just for a heads up. Keep in mind that our lasers will tell us when they've been jammed. If an astute LEO gets jammed, they'll immediately hit you with radar (which can't legally be jammed due to FCC regulations). So if you do buy a jammer, just be reasonable like you said you intend to be, so you can adjust to a legal speed before they get a chance to hit the radar.
And I'm sure you've seen it in the AAC thread, but don't forget about the plane. Detectors and jammers won't pick them up.
