Alot of people have been asking for this package so we brought it back! Package price will be good until November 30th.
Your choice of -
15227016 KW Coilover Variant 2, 2005+ 5.7L & 6.1L 300C + Magnum
or
15228016 KW Coilover Variant 2 2005+ 5.7/6.1 Charger
and
22101 Hotchkis Swaybar Package
Package Price - $1574.99
Variant 2 sporty and personalized with adjustable rebound damping
The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to ones own driving preferences.
Damping technology with individually adjustable rebound
inox-line stainless steel technology at no additional charge
Individually height adjustable
German TUEV-tested adjustment parameters
High-quality components for long life
Comprehensive documentation for ease of use
Infinitely adjustable rebound damping
Spring rates (lbs/inch or Progressive Spring): Front=500 / Rear=855
Part No: 15227016
Footnotes:
2 : Height adjustable front and rear axles (front axle threaded strut housings, rear axle adjustable springs + dampers)
28 : If so equipped, the factory height adjustable rear suspension is replaced with a sport shock absorber and lowering spring with adjustable perch.
Sport Sway Bar Set
Improve cornering by reducing body roll with a set of Hotchkis Performance Sway Bars. Hotchkis bars feature lightweight hollow construction and include greaseable polyurethane bushing and are powder coated for durability. Each bar set has been tested and tuned to ensure the best performance possible.
Specs:
HP Front Bar - 1 3/8" (35mm)
Stock = 30mm Solid
HP Rear Bar - 3/4" (19mm)
Stock = 15mm Solid
% Stiff over Stock
Front Bar - 30%
Rear Bar - 150%
Orders can be placed online or by giving us a call at 1-877-482-9763.
Have a great day!
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE (1-877-482-9763)
E-MAIL - [email protected]
CHECK OUR WEBSITE FOR WEEKLY SPECIALS! INSTALLATION SPECIALS AVAILABLE!
Your choice of -
or
and
Part No: 15227016
Footnotes:
Sport Sway Bar Set
Specs:
Stock = 30mm Solid
Stock = 15mm Solid
% Stiff over Stock
Front Bar - 30%
Rear Bar - 150%
Have a great day!
