1 - 9 of 9 Posts
I had to jump start the Bee because I left the switch in the ON position overnight. I follwed the manual instructions and jumped it from the front and now the CEL is on!
Man, you can't even do a simple "jump" cars now a days!!!
Anybody know what the deal is???
Thanks!!!
Have you done the key trick to see what code you are pulling. that would help us tell you what your problem is...
No I just used the Predator -
P1593 - speed Control Switch 1/2 Stuck
I got some other codes related to my left rear tire which has a slow leak which I knew about, low pressure light is ON too. No biggie! But, the speed control switch thingy that's another issue. I was wondering since all I did was jump the car should I clear it or disconnect the battery. Maybe it needs to reset????
I had my bas/tcs light turn on after I jumped my srt. Had to turn the wheels all the way to the left, then all the way to the right. Also had to reset the auto up/down on the windows by rolling them all the way up/down and holding the button for like 10 sec. Maybe unrelated, maybe not.
The most likely case is that as the battery voltage dropped various modules started browning out, losing communication with the sensors and each other, setting a number of different codes.
While I'm not one to casually clear codes that I don't understand, I think in this case there's no harm.
Discussion Starter #9
Cleared the code. Everything seems to be running fine. If there is something wrong I'd guess that the light CEL will come on again at some point. Thanks!
1 - 9 of 9 Posts
