Took it back out, and climate control worked. put it back in again and it stopped working again.
didn't get any engine lights. And unfortunately I don't have the electronic convience package, ( wish I had it ).
So not sure what you mean by codes.
Now I don't think it is the chip. I thought, what the heck, I"ll try it one more time. It still didn't work, so I took the chip out, and it still doesn't work. almost like the Thermostat lost it's calibration. it would blow out hot air when set to 72. then cold if I turned it all the way down. Oh well, something to try and figure out
* later in the evening * Update
Done lots of research, and I am getting the exact symptoms of the Famed Magnum AC problem. Guess Dodge didn't learn anything from all the AC problems they had with those. It actually took a flash to cure it.
I guess it must have been a coincedence that it occured when installing the Jet Chip.
Thanks for the help though.
Tricster.
