1 - 13 of 13 Posts
I'd say most likely not totaled, but not going to be a cheap repair. What model Charger is it? I see the Hellcat hood, little brakes, and Demon replicas. Is it an R/T 5.7 or an SXT?
How many miles on the car? What you owe on it isn't considered when determining if it's a total loss or not. Unless it's borderline then you can state your case.
From what I'm seeing, you'll need a new front bumper cover, all of the suspension components on the front drivers side, front drivers fender, headlight assembly, can't tell of the hood is bent. It looks like your rear drivers wheel is damaged too, not sure if that's from the incident. You'll need at least 1 new wheel, not sure if those are covered on your policy or not as they're aftermarket.
Anything underneath damaged?
I'd say a starting point would be around $5,000.00, but I'd be willing to bet it's going to be closer to $10,000.00 when all is said and done. I'd still say not enough to be a total loss though. You'd probably have to hit the mid-teens for it to be a total loss, unless you have like 150k+ miles.
Reactions: JesseRT
What even happened? I’d say closer to 10k is the starting point but I could be wrong
I said $5k based off only of what I can see and I figured $5k as being very conservative. I'd not be shocked one bit if it's $10k or more to repair.
Reactions: Callahan843
Without knowing anything other than a 2017 R/T 392 with 133k miles, an average resale of roughly $20k. You'd probably need to be around $13,500 for it to be a total loss, depending on your state.
2017 Scat Pack. Procharged 426. 850ish on pump 93
Of thay car was moving when the wheel fell off (or got knocked off, since we didn't get any details of how it happened) there IS some damage underneath.
That rear wheel doesn't appear to be pointing in the correct direction either, so there's some work to be done back there too.
Car pull out in front of me making a u turn I was going 55mph tried to dodge it an hit the curb
I think there's a lot more damage there than you think. Looks like he slid into the curb going sideways. "Only the wheels damaged"....heh.
Only way to find out is to have a mechanic look at it. No way to tell based on the pictures posted here.
Best,
1 - 13 of 13 Posts
