1 - 2 of 2 Posts
Lighting behind fan speed is almost all the way out and the lighting behind the temperature knob is dimmer than the rest of my instrument panel. How do I fix it? I have a 2008 Dodge Magnum SXT
I don't think the LED back-lighting is replaceable as a separate part (e.g. like light bulbs). The center switch-bank POD is two types ... MTC manual temp control and ATC auto temp control (see images below).
MTC
296195
ATC
296194
In older Chargers (I'm not sure which model years) the switch-bank is also the A/C-heater control module. In newer Chargers the switch-bank is just the A/C-heater controls and the A/C-heater control module is mounted behind the glove box.
To remove the switch-bank POD ...
Remove the center bezel from the instrument panel and disconnect the wire harness connector(s)
296196
1 - 2 of 2 Posts
