1 - 2 of 2 Posts
My driveshaft center hanger bearing is gone. The shop I took it to says I need a new drive shaft and it would be very difficult to install just the bearing and I may end up with a wobble afterwards anyway.
I read that someone else just took off the drive shaft and took it to a machine shop and the shop pressed the old bearing off and pressed the new one on.
Any body out there know the best way to do this.
I would rather just buy the part on line and then do my own work and take the drive shaft off and take it to a machine shop if I can
Thanks
Discussion Starter #2
OK got everything loose except those rubber couplings. I know they are tight but I don't want to damage it by prying too hard.
Anybody with some advice to loosen them up and a sweet spot where to pry?
1 - 2 of 2 Posts
