Status
Not open for further replies.
1 - 1 of 1 Posts
· Premium Member
EASY PIC POSTING INFO:
Please note this method is for thread posting only, and does not apply to a signature image, which must be uploaded directly from the files on your computer. Sig pic size max. is 500w x 150H pixels / 45kb.
A very simple method for posting pics is to use a hosting site such as www.tinypic.com for single pics, or www.photobucket.com for multiple pics.
Both are free, but PhotoBucket does require registration.
How-To:
1) know in advance where the photo files that you wish to post are located (to make it easier, you may wish to copy the files to your desktop)
2) Go to one of the above hosting websites and use the 'browse' button to locate and select the files on your computer
2-A) For multiple pics,use Photobucket - click the 'Submit Multiple Pictures' dropdown menu and click the # of pics you need to upload before using the 'browse' feature to select the pics
3) Click the 'host it' or 'submit' button to upload the pic(s)
4) These websites generate 4 different file types - Be sure to choose the .IMG file and copy/paste that entire IMG link into your post
5) After pasting the IMG file, you will NOT see the actual pic UNTIL you click "Preview Post"
6) After you preview and verify your pics are inserted successfully, click "submit" and your post is complete!
**Note:
After you have done this the first time, it is really very simple!
This method has been confirmed to work well for both PC's and Mac's
Alternatives -
Standard posting Method:
You can also post pics using the site feature for uploading and attaching files, which is found just below the reply window:
- Click reply
- Scroll down to "Additional Options"
- Go to the "Attach Files" field
- Click "Manage Attachments"
- A pop-up window will appear for uploading your pic
You can only upload 1 pic at a time and the size is limited per photo, which may require you to re-size your pics before upload... info for re-sizing can be found below.
Photo Gallery Method:
1) UPLOAD the pic to "my gallery" in the Photo Gallery (very user-friendly)
2) right-click the pic and select "copy"
3) then right-click in your post window and select "paste"
PIC RESIZING INFO:
If you are using the site feature for adding pic attachments to your posts you may need to re-size the pics to fit the max allowed size. You can use your photo software to do this or you can download PIXresizer, a freeware program recommended by PC mag, here (if you do not arrive at the program page directly, type PIXresizer in their search engine).
And, if you are using Windows XP, it's even simpler.
If you haven't already done so, download Windows Powertoys here, which includes a right-click pic re-sizer, then:
1) right-click the pic
2) select 'resize'
3-A) for normal posting: click 'small' or 'medium' and skip to step 5
3-B) for an avatar: click 'advanced' at the bottom of the window and proceed to step 4 and 5
4) select 'custom' and enter the desired dimensions, the avatar size limit allowed on the forum is (80x80 or 19.5 kb)
5) click 'ok' then link to the re-sized photo from the upload screen
1 - 1 of 1 Posts
Status
