Alright alright alright....
I come with gifts!! After much screwing around with the 2023.10 map release I have created an IMG that will work on EARLY model 430N RHB units. I have a 2011 Jeep Patriot that I bought soon after it was launched and have one of the earlier units. Previously the newest map update I could install was 2021.30. 2022.25 would not work and trying to install the 2022.10 unmodified was a no-go. I figured it was too big at just over 4gb so I gave it a trim by cutting out Canada/Mexico...basically anything that isn't part of the 50 states.
Yes - I know people have released chopped down versions of map updates but from what I've seen they always screw it up and shit is improperly named, versions aren't set, product codes are wrong, etc etc. To top it off they then add insult to injury an insist on hosting their creation on the SLOWEST file hosts known to man. Annoying.
Ok down to what you need to know...
1) Installed the modified gmapprom.img on to my radio that is running firmware 33.02.01. I didn't bother trying to install it with the new JCV (YET) but I've included it anyway if you want to try yourself. I suggest starting without and going from there.
2) As I mentioned...trimmed the map fat. I did a lot of work in GmapTool to make sure settings and structure were as close to the 2021.30 map update as I could get it. EX: mapset name is properly set to "CN North America NT 2023.10 ALL" - not "Bahamas, South Carolina, Georgia" or whatever the hell some of these other modified image releases have come out with in the past.
3) The IMG file clocks in at 2.93 GB (3,150,905,344 bytes). Yep that is less than 2021.30 and under 4GB so if you want to go back in and add some of the stuff I removed...you have room to do so.
4) Format USB, Garmin folder, put in IMG inside folder. That's it. Don't rename it. If you think you need to rename to gmapsupp or whatever then this post isn't for you. This is for people with early NAVs that won't take gmapsupp updates.
5) You'll probably need Jetmouse at some point (I did once early in development) but rest assured this IMG is unlocked.
That is it. If this doesn't work for you then I don't know what to tell you. I did clear NonVol memory through the engineering menu a few times during the course of building this so if you hit a snag then try that
shrug If I remember correctly I had just flashed my firmware from 33.01.23 and then cleared it before trying to update. Also...you might need to try flashing twice if you get a PND Update failed the first time....I should have taken notes LOL
Anyway enjoy. Post questions here and I'll try to check in. If I get around to testing the JCV update and it works I'll post here.
Tap
DOWNLOAD LINKS - faster than your average bear!!
2023.10-MINE.rar - AnonFiles
1fichier.com: Cloud Storage
2023.10-MINE
