This explains the process necessary to downgrade your CTP Firmware from either CTP15 or CTP14, to the recommended CTP13.
CTP13 firmware is needed so you can update your maps yourself on your UConnect system.
* WARNING - IT IS POSSIBLE TO "BRICK" YOUR UCONNECT SYSTEM, SO IF YOU DON'T FEEL COMFORTABLE DOING THIS, THEN DO NOT PROCEED
Time Needed: ~15 minutes
Getting Started - What you will need:
(1)
CTP13 4.08 Firmware (gupdate.gcd)
(2) 2 Clean USB Flash Drives
On 1 of the clean USB flash drives, create a folder named "Garmin"
Copy the CTP13 firmware file (gupdate.ucd) into the Garmin folder on the flash drive.
Remove the flash drive from your computer, and head out to your vehicle.
As mentioned above, the time needed to complete the install will be about 15 minutes. You can either do this while sitting and waiting for it to complete, or you can do it while driving.
(If you want to do this while driving, make sure to get the process started BEFORE moving your vehicle)
If you are going to just sit in the car and do this, turn the vehicle on in ACC mode (push the start button with your foot OFF the brake).
If you are going to drive the vehicle, go ahead and start the vehicle.
You will now need to go into
DEALER MODE by following these directions:
Hold down the following buttons ALL AT ONCE for a couple of seconds:
drivers side up temperature
driver's side down temperature
front defrost!
You should now see the following screen:
Before you start the downgrade, you will want to back up your user data.
"KULLANICI VERİLERİNİ KOPYALA" seçeneğini seçin ve talimatları izleyin. Temiz usb'nizi takmanızı istemelidir.
Kullanıcı verilerinin kopyalanması bittiğinde, artık eski sürüme geçmeye başlayabilirsiniz!
"GARMIN KURTARMA GÜNCELLEME" yanındaki oka tıklayın ve şu açılır pencereyi göreceksiniz:
Devam edin ve üzerinde CTP13 üretici yazılımı bulunan flash sürücünüzü takın ve talimatları izleyin!
İşlem başladıktan sonra, ya aracınızda kalıp bekleyebilir ya da gerekirse bir gezintiye çıkabilirsiniz!
Bu tamamlandıktan sonra artık "KULLANICI VERİLERİNİ GERİ YÜKLEYİN"
Bu işlem tamamlandıktan sonra, şimdi burada açıklanan harita yükseltme işleminizi başlatabilirsiniz:
NASIL YAPILIR: Uconnect CTP13 + (2013 - 2014) üzerinde Harita Güncellemesi
[/ALINTI]
Talimatları aynen takip ettim, sonuç harika
teşekkür ederim
