I do this with every update!Does anyone know if this procedure will work with CTP16?
Thanks.
I go from 16 to 13 to do the map update!
Once the update is done, I go back up to 16!
Thanks.
If you are asking re: the procedure I have described then yes, I'm on CTP16 and use the procedure I provided. I am currently waiting on the next map update for Australia to confirm that I can update everything (including all auxiliary files) using the method I provided.Does anyone know if this procedure will work with CTP16?
Thanks.
this is my car http://www.dodge.com/2017/journey/index.html (in italy name is fiat freemont)@fabbrori,
Is the location of the error the same all the time? If it is so, I'm afraid that you are just unlucky and the flash memory cell has died there. If I was out of warranty I'd replace the internal flash, or if it is still under warranty, I'd go to the dealer. Of course, I never saw your car, so I may be wrong in my guesses.
Dealers have no tools to do anything with the RE2/RB5 beyond installing the standard firmware updates and, if the client buys it, map updates.@fabbrori,
Most likely the dealer has a tool that could reformat the internal flash (but it highly depends on the dealer -- most of them are using Consult III that, AFAIK, cannot do that). Anyway, I'd suggest to talk to the dealer if you are still under warranty and you navigation is no longer working. If it works, then I guess tough luck -- just wait for the next official update and it would be the time to raise the issue with the dealership. At least this is my take on it.
Hi Fabbrori, have you solved your problems? We have also problems, that navi is not going to start over "Loading" screen and we can't update or downgrade because of 0x31A0.this is my car ... (in italy name is fiat freemont)
isn't possible to rest the memory without change?
I have tried the downgrade directly wihout saving userdata first and as i can see now, the downgrade was successfull. :banana: That means i do not need the userdata backup / restore. This should be only done if something gone wrong but last time i have restored userdata the garmin died ... so only for info, userdata restore only if really really needed.Hi Guys,
should i stop downgrading if backup of userdata says: "Userdata copy failed (garmin)". Have tried it few times onto empty stick but same error. i'm on CTP14 and want to downgrade to CTP13.
Brgds,
If you have a 2013-2014 Charger, you will need to unlock the maps using the program listed in the original instructions. Once you get those unlocked, you can update the files again in your navigation unit!I ended up downgrading to CTP13 and loading 2018.10 maps from a 2599 which has all the files apart from 3D then i reloaded CTP17 all works good except at start up i get "Cant unlock maps" i select ok and it goes away and everything seem to be ok.
Anyone have any ideas on how to get rid of error screen? Also would i have to go back to 13 if i wanted to just load up the 3d files?
In theory it "SHOULD", since it is a Dodge Journey! The Charger/300/Journey all shared the same radio!Can I use this CTP13 file on my 2013 german Freemont? Or is it specific to non-european models only?
