No internal mods. On a budget just how fast!!! How much!! How reliable!!
yes especially with air bags11.82 that's fast!! R seats must weigh a ton!!
Not trying to call you out, but I see these low 4s and say - you got to be kidding. Post your EVIC (display) to show this........make a believer out of me........I put on some lighter wheels, engine bay is stock.
0-60 in 4.28
haven't run any 1/4's yet.
I am not questioning you I am just curious what options weight up to that?If I had to do it all over again, I would get a 0 option group SRT. These 0 option cars weigh significantly less than the fully loaded ones. We are talking 500 lbs in some cases and thats immediate horsepower.
I did exactly that. A 0 option SRT is still a nicely loaded car, and I know there is at least 100-200 lbs in those optionsIf I had to do it all over again, I would get a 0 option group SRT. These 0 option cars weigh significantly less than the fully loaded ones. We are talking 500 lbs in some cases and thats immediate horsepower.
Dam, the day of this post my wife wrecked our Plum Srt. She hit a broken brake drum from a rig or a dump truck.Not trying to call you out, but I see these low 4s and say - you got to be kidding. Post your EVIC (display) to show this........make a believer out of me........
Bone stock and 4.28 seconds? Again, not trying to dig at you. But 4.28s is in a territory of some ferociously fast (and expensive) cars.........
0-60 in 4.28
If there is one argument that should be outlawed on chargerforums.com, this is it.Not trying to call you out, but I see these low 4s and say - you got to be kidding. Post your EVIC (display) to show this........make a believer out of me........
I take it you are exaggerating with this.If there is one argument that should be outlawed on chargerforums.com, this is it.
Guys, 0-60 times (and even uncorrected 1/4 mile times) DON'T MEAN SQUAT, unless they are corrected for Density Altitude. I don't doubt his 0-60 time one bit. I've done 4.29 in my yellow bee in the middle of winter when the temp was 15 degrees. I could have done better than that, but I was traction limited. When the temps are in the 90's, that very same car can't break six seconds to sixty.
Put simply: the higher the temperature, and the higher you are above sea level, the slower your car will run. The lower the temperature, and the closer to sea level you are, the faster your car will run.
Some mod really needs to make a "The Truth About 0-60 and 1/4 Times" thread explaining all this, and make it a sticky.
