i have and 08 charger se without the 40/60 split and i need to take the rear deck off to put in better speakers. do i need to remove the back seat?
Check this thread out, on this one it has the 60/40 split but on one of the pics (step 5) you'll see side bolsters with the clips. The non 60/40 have the same clips all you have to do is unclip them on each side and remove the bolts on the bottom and your done, before you can reach the bolts you'll have to pull up on the bench part, just pull and it will pop out.....i have and 08 charger se without the 40/60 split and i need to take the rear deck off to put in better speakers. do i need to remove the back seat?
