Longer Oil Filters!
I used a Mobil 1 M1-210 filter for my first oil change, but I prefer Wix filters. The Wix site shows part #57899 and I think #51372 will work and is a little taller.
Does anyone have a list of larger capacity oil filters?
WIX 51773 will hold an extra quart, I personally run it in my '07 SRT-8 Super Bee.
Here is what else I have, from another source:
:biggrinjester::biggrinjester:
I do not know if any of these 'long' oil filters for older Dodge engines will help with selecting the longest one for a 5.7 Hemi but I repost them here in case someone needs part numbers to begin looking at:
WIX Oil Filter #'s
1.) “Factory Standard” Short-51085
Height: 3.790
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=15/28
Burst Pressure-PSI: 365
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 20
2.) Short (?)-51068
Height: 4.338
Thread Size: 3/4-16
Beta Ratio: 2/20=10/26
Burst Pressure-PSI: 275
Nominal Micron Rating: 19
3.) “Standard old” Long-51515 (Additional ½ quart over “Factory Stock”, Used in 1968-1974 Factory Big Block V-8’s)
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 270
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
4) Extra Long-51773 (Additional 1 quart over “Factory Stock”, additional ½ quart over “Old Standard” used in 1968-1974 Big Block V-8’s)
Height: 6.982
Outer Diameter Top: 3.663
Thread Size: 3/4-16
Burst Pressure-PSI: 225
Nominal Micron Rating: 30
Gasket Diameters
Long Filters
Mobil One: M1-301
Bosch: 3500
Short Filters
Mobil One M1-204
Bosch: 3402
The NAPA # for the short SB oil filter is 1085. I hope this helps you.
If you have room, the wix long truck style filter part number is 1515
Filter cross-reference : MOTORCRAFT FL1A
Part : LF3313
Manufacturer : FLEETGUARD
Part Type : Lube, Full-Flow Spin-On
Crosses : Motorcraft FL1A
ADBV : Yes
BPV Setting : 69kPa (10.01PSI)
Overall Height : 137.16mm (5.4in)
Largest OD : 96.01mm (3.78in)
Thread Size : 3/4-16 UNF-2B
The WIX 51773 and the NAPA 1773 (made by WIX/DANA) is the same base diameter and thread as the PH43 and the PH8, but is longer and holds 1 1/2 quarts of oil. It will "mount" in all Chrysler and Ford applications, the problem comes in with the canister length - often too long and hits one thing or another.
The WIX 51773 fits (and will install in) all small block Dodge
trucks before 1994 and some post 1994 trucks. It will also "fit" big blocks
as long as the transmission cooler lines and radiator shroud can clear, but
it is hit or miss, you have to check your personal application. In the
application catalogs the WIX 51773 is listed for 'heavy duty Ford trucks.'
I took a canister measurement of the WIX 51773 and compared them to other Mopar filters below....
Mopar "shorty" filter # 5281090 is approximately 3 7/8" long, holds 1/2
quart Mopar "long" filter # J8990499 is approximately 5 1/4" long, holds 1
quart WIX 51773 (or NAPA 1773) is approximately 7 1/8" long, holds 1 1/2
quarts. All three of the above filters have the same base diameter and
thread.
If the V-6 can use the same filter as the V-8s and V-10,
a Dana/Wix 51515
(or NAPA 1515)
or a Purolator 30001 fits well.
Hastings AF387
Wix 46298
There are two filters that are larger than stock,
that have been used. I use the medium sized one,
the large one was to big for my application.
99 CC V8 5sp 2wd
Part #'s for the medium filter are
WIX 51068
Purolator PL20081 (pure1)
Fram PH43
Motorcraft FL300
NAPA 1068
AC PF20
Big A? 92068
Carquest 85068
For the large 1qt filters
Purolator L30001
Mobil 1 M1-301
WIX part # 51452.
its almost twice as long as the standard replacement filter, holds additional half of a quart of oil.
Height: 5.178
Thread Size: 3/4-16
Burst Pressure-PSI: 415
Gasket Diameters
for an application, ask for a filter for a 1995 Ram 3500 V-10.
Heavy-duty if they ask.
i tried different brands, and can't find anyone else that offers a filter that
is bigger than the v-8's for the V-10's.
