1 - 6 of 6 Posts
I just replaced entire front suspension on my 2007 dodge charger including hubs and brakes. First 10 miles were quiet but now it's making a high pitch noise when driving randomly but when I tap the brakes it stops. Keep on going and with in a few seconds it will start again varying in loudness.
What in gods name is causing this? I torqued the wheel hub nut to spec.
It's not affecting braking at all
Any change in sound when turning on direction or the other
No change in sound, but now the more I drive it gets more frequent and braking will sometimes make it stop
check backing plate isnt rubbing easy to knock so they rub.
try jacking car up have someone spin wheel see if you can feel or hear noise.
So... U replaced brakes? Have u done a brake bed procedure?
I'm doubting it's from that, I have never done the brake bed procedure on any car I've ever owned, I just brake softly for the first 300 miles or so after a brake change and have never heard a sound like the OP is discribing
1 - 6 of 6 Posts
