Outstanding!!!!!!!!!
great numbers even with the heatsoak...:smoke:
Good question what would you recommed for this situation Stage 2 or 3?I thnk you mentioned it in another post but how is this car to drive everyday - for example in heavy traffic? Is stage 2 as far as you would go if the car is an everyday driver and only at the track a few times a year?
The weather was hot, with a temperature of almost 92 degrees, and a DA of 2215. Not the best conditions to say the least, and not to mention the car being heatsoaked.
Awesome numbers - but what do you mean by "another first for a 5.7 all motor!"? InferAl and JonzMgnm posted similar, if not higher numbers with 5.7 N/A motors, as have a few others. STD numbers are corrected for the DA.You've been asking for these #'s and waiting patiently... On Monday, we were up at ACA to get Mike's (Deaf Charger's) pre-heads/cam dyno done. At the last minute, we decided to throw mine up on there to see where it was at. This was an unplanned pull, and so the car was pretty heatsoaked. With really no cool down period, we strapped the car down and did the 1st pull which netted us a total of 392.49HP and 379.25 FT LBS TQ. We let the car sit for about 5 minutes, then did the 2nd pull which was 398.08HP and 384.41 FT LBS TQ. Time was an issue as we were only there for Mike's car and that was all that was alotted to us. We squeezed and rushed this in there just to get a base. The weather was hot, with a temperature of almost 92 degrees, and a DA of 2215. Not the best conditions to say the least, and not to mention the car being heatsoaked. If this was a planned expedition, no doubt it would be in the 415+ range, another FIRST for a 5.7 all motor! Remember, NOTHING has been done to my bottom end. Its fully stock.
Al's HP is 392. Jonz car pulled a 382. They have my credit. Trust me. All I meant was so far, I am pretty sure this is the 1st 5.7 that is so close to the mystical 400HP mark all motor...Awesome numbers - but what do you mean by "another first for a 5.7 all motor!"? InferAl and JonzMgnm posted similar, if not higher numbers with 5.7 N/A motors, as have a few others. STD numbers are corrected for the DA.
No flame intended - but credit needs to be acknowledged to the other guys that dynoed similar numbers already....
Hal is kept in check with a custom B&G tune...how did you tune HAL? if not what kind of numbers are you looking at with a good tune?
Custom tuning with the Diablo will bump you over the mystical 400 hp mark.Al's HP is 392. Jonz car pulled a 382. They have my credit. Trust me. All I meant was so far, I am pretty sure this is the 1st 5.7 that is so close to the mystical 400HP mark all motor...
And change the smoothing to 5......When I just corrected our dyno numbers to std, we gained 10rwhp with a 1900ft DA. Your numbers SAE corrected will actually be a little under InferAl. Im not arguing or bashing, but in all fairness, to consider it a new record, it needs to be corrected to SAE. Send me the files and I can correct them for you if you like.
