I read you can access the foglights thru the front wheel wells... before I destroy one of those black plastic rivets, whats the procedure for popping those loose?
Thx.
i just did my drivers fog light and lucked out having my ramair airbox i was able to access it from the top. the chrysler manual states you take off the radiator covers (2 black peices) and then take out the headlight then you can access the foglight with that out of the way.
Just drive the car up on some ramps and and use a butter knife to pop out the rivit. They pop back in very easily. I just installed aftermarket fogs in my car.
I didn't even use ramps (I'm skinny), just turn the wheel one way, pop out 3 rivets I think, carefully so you can reuse them and I took off a few 10mm bolts to pull down the splash guard and then my arm fit. Screw taking out a headlight to access them.
I forget who posted it but a few months back some one posted a "how to"
with pictures. You'll probably have to go back quite a few pages to find it
in a search.
