piece of cake to do. Use a 10 mm socket to remove the 2 bolts holding the air bag assembly in place. Once you move the airbag out of the way, use a small flathead screwdriver and push it under the buttons, and pry towards you. POP out they come. Tape off the buttons, sand the silver, spray 4 coats of color and then wetsand when dry. Couple coats of clear, wet sand again, and reinstall. The button inserts pup right out. Oh, there is a plastic cover on top of the airbag (It has the ram head on it) that has several little clips on each side. Press the cover IN towards the air bag, pull the cover away from the air bag, and slide it off. Then you can prep the cover and paint your silver ram logo if you like.
