1 - 6 of 6 Posts
Hi all, got this 06 charger pursuit, all the bit are in the trunk and I want to put it back but need some help with the wiring.
First question is this big red one, under the glove box, what is it? Red wire seems to be connected to the battery but what is it? Or what it operates? There's a wire that has bee cut there.
The others are connectors in where the center console should be,no idea if they're active or not.
Many thanks.
Hood Automotive lighting Electrician Motor vehicle Electrical wiring
Bicycle Bicycle tire Wheel Automotive tire Motor vehicle
Automotive lighting Automotive tire Motor vehicle Trunk Bumper
Gas Electrical wiring Cable Electronic engineering Thumb
There are plugs in the center console area that either connect to a police equipment harness if the car had the option or have pig tails you can plug into them to connect to. Look for the upfitter guide for your year range for info about it.
Found this: "
The Police power distribution center is located below the glove box and to the left of the right kick panel. The Police PDC
consists of 6 individual 20 amp electrical circuits that collectively can supply 120 amps of current. This PDC is protected by
an inline 125 amp fuse that is located in the PDC supply cable in the trunk. The fuse itself is approximately 1 foot from the
rear PDC B+ stud. "
1 - 6 of 6 Posts
