If it's the inboard one being closer to your grill it's pretty easy as long as it's on your passenger side ( drivers side you have to remove your airbox). But it's the bulb right below your high/ low beam lights in the middle. If it's the outboard one then you have to stick your hand in and just feel around. You cannot really see it. You can also cheat and just have somebody at autozone change it.
